Multi-species transport algorithm in OpenFoam
Like Tree1Likes
  • 1 Post By RobertHB
Old   September 11, 2018, 11:01
Default Multi-species transport algorithm in OpenFoam
Robert
RobertHB is on a distinguished road
Dear Foamers,
i want to simulate the transient advective/diffusive transport of multiple species (Al/Na/Si) through a liquid phase. I'm just missing a suitable solver.
The same can be done with one species in scalarTransportFoam, but the equation does not allow for the use of multiple scalar quantaties.
Everything in multiphase/... can handle multiple liquid phases, but does not seem the simulate the advection/diffusion of dispersed species.
A quick idea that came to my mind, but has to be tested, is running scalarTransportFoam for 1 species, and add the other the via a function object during runtime. Similar what was suggested here. Or even better run icoFoam and add all three species via function objects?
Can you name a suitable solver for this kind of simulation?
With kind regards,
Robert
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   September 12, 2018, 07:09
Robert
Results from the icoFoam - scalarTransport function object experiments.
Adding a species w/ a function object like it was explained here does nothing at first. Here is my example:
    Aluminium
        type                scalarTransport;
        functionObjectLibs     ("libutilityFunctionObjects.so");
        field               Al;
        active              true;
        autoSchemes         false;
        D                   0.47e-8;
        nCorr               1;
        resetOnStartUp         false;
        fvOptions
            SourceNa
                type scalarSemiImplicitSource;
                active true;
                scalarSemiImplicitSourceCoeffs
                    volumeMode    absolute;
                    selectionMode cellSet;
                    cellSet c0;
                    injectionRateSuSp
                        Al (4.3e-4 0);
After adding #includeFunc scalarTransport to the controlDict icoFoam can start solving for a species called s. s can not be modified with the code presented above.
But, as soon as #includeFunc scalarTransport is inlcuded in the controlDict icoFoam starts also solving for the species defines by the code. At least the fvOptions source. It does not solve the transport.
Luiz likes this.
multi species transport, species distribution, transport model
Species Transport Anne009z FLUENT 0 January 27, 2018 15:40
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
Multi Species Problem (mass fraction) usamaperwez CFX 0 July 27, 2016 08:07
analyze results of species transport sunflower FLUENT 0 May 11, 2012 05:49
