Moukalled, et al - The Finite Volume Method in Computational Fluid Dynamics - 2015 |
August 25, 2018, 10:00 |
Sergei
Rep Power: 21 |
A raw list of misprints found in the overall excellent book. Unfortunately, it is not well formatted but may be usefull for someone anyway.
page 032, eq. (2.78): Error in expansion of double product. page 062, para. 1: "Then by substituting h - p/rho ..." -> "Then by substituting h_0 - p/rho ..." page 065: Term 1. "Change of of phi over time..." -> "Change of phi over time..." page 070, eq. (3.106): "d(rho u u)/dt" -> "d(rho u u)/dx" page 106, para. -1: "... only one integration point located at the centroid of the face is used with a weighing function of value equal to 1 (i.e., ip = ?ip = 1)." -> "... only one integration point located at the centroid of the face is used with a weighing function of value equal to 1 (i.e., ip(f) = ?ip = 1)." page 117, eq. (5.37): first term on lhs: "d(rho phi)/dt" -> "d((rho phi)_C)/dt" page 161, para. 1: "Compute the weighing factor using Eqs. (6.26) and (6.27)..." -> "Compute the weighing factor using Eqs. (6.29) and (6.30)..." page 161, para. 2: "To calculate the interpolation factor using Eq. (6.26)..." -> "To calculate the interpolation factor using Eq. (6.29)..." page 161, para. -1: "The calculation of gf based on Eq. (6.27)..." -> "The calculation of gf based on Eq. (6.30)..." page 162: "The interpolation factor using Eq. (6.27)..." -> "The interpolation factor using Eq. (6.30)..." page 202, Listing 7.52: "ac[l[faceI]] -= Lower[faceI];" -> "ac[l[faceI]] += Lower[faceI];" page 202, Listing 7.52: "ac[u[faceI]] -= Upper[faceI];" -> "ac[u[faceI]] += Upper[faceI]; page 204: "writeMeshObj: For mesh debugging... javaview." -> "writeMeshObj: For mesh debugging... ParaView." page 218, para. 1: "...Numerical solutions follow the same constrain,..." -> "... Numerical solutions follow the same constraint,..." page 222, eq. (8.42): "gDiff_b" -> "1/d_Cb" page 263, para 1: "The “deltaCoeffs.internalField()” represents the gDiff field..." -> "The “deltaCoeffs.internalField()” represents the 1/d_C field..." page 270, Ex. 9a: "...and then under then name fvcLaplacian." -> "...and then under the name fvcLaplacian." page 301, Ex. 7: "Hint: r_f - r_f' = r_f - r_C - r_cf' = r_f - r_f - r_Ff'." -> "Hint: r_f - r_f' = r_f - r_C - r_Cf' = r_f - r_F - r_Ff'." page 308: "Back Substitution Algorithm... phi_i = (phi_i - Term) / a_ii" -> "Back Substitution Algorithm... phi_i = (b_i - Term) / a_ii" page 322, para. -2: "... or that the root mean square residual be smaller than ..." -> "... or that the mean square residual be smaller than ..." page 323, eq. (10.71): "phi_j__(n) = ..." -> "phi_i__(n) = ..." page 349, para. 2: "The interpolation or prolongation to the fine grid level is denote as..." -> "The interpolation or prolongation to the fine grid level is denoted as..." page 368, fig. 11.2: Y-axis' name is incorrect. "(phi - phi_W)/(phi - phi_E)" -> "(phi - phi_W)/(phi_E - phi_W)" page 391: "Substitution of ..." -> "Substituting ..." page 391, eq. (11.90): It seems to be wrong when "m_e_dotted" and/or "m_w_dotted" are negative page 396, eq. (11.111): "... -1/4 phi_w ..." -> "... -1/4 phi_W ..." page 406, eq. (11.138): first line, last expression after equality sign "... = ... phi(x,t)" -> "... = ... phi(t)" page 406, eq. (11.139): first line, last expression after equality sign "... = ... phi(x,t)" -> "... = ... phi(t)" page 408, eq. (11.142): "(phi__D - phi__C) / 2 delta zetta" -> "(phi__D - phi__U) / 2 delta zetta" page 420, para. -2: The sign "++" is written as an upper index (superscript) while it should be a regular one here: "(C++ requirement)" page 432, fig. 12.2 (b): In the picture sitting on the 3rd column: "phi__C__tilde > 0" -> "phi__C__tilde > 1". page 446: How did eq. (12.40) follow from eq. (12.39)? page 450: "This follows from the fact that... phi__f = phi__V ..." -> "This follows from the fact that... phi__f = phi__C ..." page 453, eq. (12.60): The left and central parts are not necessary. page 471, eq. (12.112): "... Summation(m__f__dot + m__b__dot) ..." -> "... Summation(m__f__dot) + m__b__dot ...". page 499, eq. (13.33): "... = b__C + a__empty_circle__C*phi__empty_circle__C" -> "... = b__C - a__empty_circle__C*phi__empty_circle__C". page 520, eq. (13.94): "a__empty_circle__C = (dt - dt__empty_circle)/(dt + dt__empty_circle) ..." -> "a__empty_circle__C = (dt - dt__empty_circle)/(dt * dt__empty_circle) ..." page 527, Listing 13.4: According to the Listings 13.3 and 13.5 "rho.dimensions()" should be included in the product: "vf.dimensions()*dimVol/dimTime" -> "rho.dimensions()*vf.dimensions()*dimVol/dimTime" page 555, para -1: "The source term looks slightly different from the right hand side of Eq. (14.4)..." -> "The source term looks slightly different from the right hand side of Eq. (14.9)..." page 571, eq. (15.42): "-rho__e * D__e__u * (dy__w / dx__w) ..." -> "-rho__e * D__e__u * (dy__e / dx__e) ..." page 586, eq. (15.54): Some symbols are messed up. page 595, eq. (15.100): "... - D__f__v__with_bar ( ..." -> "... - rho D__f__v__with_bar ( ..." page 600, second line: "= 0.5 [ ... p__ww__(n) )] ..." -> "= - 0.5 [ ... p__e__(n) )] ..." page 602, eq. (15.109): Some symbols are messed up. page 612, eq. (15.140): "... e__b)e__b" -> "... n)n". page 626, para. 1: "SIMPLE algorithm where v__primed is computed from Eq. (15.83) ..." -> "SIMPLE algorithm where v__primed is computed from Eq. (15.85) ...". page 626, para. 3: "Using Eq. (15.181) with the Rhie-Chow interpolation ..." -> "Using Eq. (15.182) with the Rhie-Chow interpolation ...". page 635: "and substituting into Eq. (15.179), the extended Rhie-Chow ..." -> "and substituting into Eq. (15.213), the extended Rhie-Chow ...". page 660, eq. (16.14): "rho__f__prime v__f * S__f" -> "rho__f__prime v__f__* * S__f" page 660, eq. (16.14): "(m_dot__f__* / rho__f__* * S__f)" -> "(m_dot__f__* / rho__f__*)" page 664, eq. (16.26): "... mu ..." -> "... lambda ..." page 670: "Equation (16.37) can be rearranged to give the static..." -> "Equation (16.38) can be rearranged to give the static..." page 681, list. 16.10: "ppEqn.solve();" -> "ppCompEqn.solve();" |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
The aspect ratio of the volume elements in Finite Volume Method | CharlieTan84 | Main CFD Forum | 3 | August 28, 2012 02:34 |
Control volume based finite difference method? | mukut.medhi | Main CFD Forum | 3 | August 24, 2012 10:01 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
