boudary condition for 2 inlets 2 outlets
Like Tree1Likes
  • 1 Post By RobertHB
Old   August 16, 2018, 17:46
Default boudary condition for 2 inlets 2 outlets
salomama is on a distinguished road
Hello, i am having a difficulty trying to run a simulation of an open test section, so i have two inlets and two outlets, the first one flows directly into its outlets with a velocity of 22m/s and the second located right below it that is considered the atmosphere and it has an outlet too so they are both 0m/s since they are outside the test section, did that just to see how thick is the shear layer outside the test section, but for days now it is giving me errors first because of the time setting in controlDict but just to make sure that it is a boudary condition problem because i see some weird outputs in the animation;
u file
internalField uniform (0 0 0);
boundaryField
farfield
type zeroGradient;
inlet
type fixedValue;
value uniform (22 0 0);
outlet
type inletOutlet;
inletValue uniform (22 0 0);
value uniform (0 0 0);
symmetry
type symmetryPlane;
rightside
type inletOutlet;
inletValue uniform (0 0 0);
leftside
type fixedValue;
frontAndBack
type empty;
p file
internalField uniform 0;
boundaryField
farfield
type zeroGradient;
inlet
type fixedFluxPressure;
value uniform 0;
gradient uniform 0;
outlet
type totalPressure;
rho rho;
psi none;
p0 uniform 0;
value uniform 0;
symmetry
type symmetryPlane;
rightside
type totalPressure;
rho rho;
psi none;
p0 uniform 0;
value uniform 0;
leftside
value uniform 0;
gradient uniform 0;
frontAndBack
type empty;
and the time
application icoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 0.05;
deltaT 0.00005;
writeControl timeStep;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
it is running in asmall short period but at least showing me something cuz i couldn t figure out how to set the time.
so this is the image of animation
it doesn t make sense because i see the red color outside the test section where there is no velocity!
your help is very much appreciated
File Type: jpg Screenshot from 2018-08-11 12-02-48.jpg (99.5 KB, 46 views)
salomama is offline   Reply With Quote
Old   August 17, 2018, 05:08
Robert
RobertHB is on a distinguished road
There is a pimpleFoam tutorial called channel395 the has a box similar to yours. Maybe that can guide you in setting up your case.
salomama likes this.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   August 17, 2018, 13:48
thank you so much
#boundary;#inlet, #timestep
Difference solution of boudary layer: how to set the initial condition wyj216 Main CFD Forum 1 June 4, 2015 06:50
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 07:40
Outlet Boudary Condition for Fully Developed Flow Saad Main CFD Forum 5 November 19, 2004 14:22
