Material diffusion coefficient in OpenFOAM
Like Tree1Likes
  • 1 Post By clapointe
Old   July 13, 2018, 05:27
Unhappy Material diffusion coefficient in OpenFOAM
Kikuta Enoki
Kikuta.K is on a distinguished road
Hello Foamers.
I'm trying to add selective diffusion of hydrogen to reactingFoam, but I don't know where I can edit material diffusion coefficient.
Is diffusion coefficient calculated from Sutherland coefficient?
How can I edit and add selective diffusion?
I am sorry for not being excellent in OpenFOAM yet.
Hopefully anyone could help me to fix this problem?
My OpenFOAM is version 4.x.
Best regards.
Kikuta.K is offline   Reply With Quote
Old   July 13, 2018, 15:28
clapointe is on a distinguished road
reactingFoam uses the effective viscosity for species diffusion -- if you use sutherland viscosity then yes, it'd be used for computing (bulk) species diffusivity in the laplacian term. If you want to add differential diffusion, you'll need to compute diffusion coefficients for each species. There are various threads on this -- here's one for example : Difficulties with premixed laminar methane flame in openFoam.
Caelan
clapointe is offline   Reply With Quote
Old   July 16, 2018, 08:43
Kikuta Enoki
Hi clapointe.
Thank you for your quick reply. (and I'm sorry for my late reply)
I have read the thread which you indicated.
Thank you for providing me another thread.
I've tried to imitate the code which was indicated by Chris to be able to calculate species diffusion, but didn't work well because of the difference of the solver.
Do you know another similar thread in reactingFoam?
If it's possible, I want you to provide me any other informations.
Thank you!
Old   July 16, 2018, 12:30
There really is not much difference between reactingFoam and fireFoam if fireFoam is used solely as a solver for reacting flow -- assuming a turbulent Prandtl number of 1 will pretty much make muEff = alphaEff, and the hEqn's are identical. This still assumed a unity Lewis No -- you can compute a bulk species diffusivity for non-unity Lewis No as done by FM global in their fireFoam repository : https://github.com/fireFoam-dev/fire...solver/YEEqn.H. Computing species-specific diffusion coefficients will be more involved -- see eg. : https://www3.nd.edu/~powers/ame.60636/transport.pdf.
In the thread I referenced, it looks like the Lewis No for each species is being taken into account.
Caelan
Gaozw likes this.
Old   July 29, 2018, 22:10
Gao Zhengwei
Gaozw is on a distinguished road
Hi, foamers,
I am also making efforts to add speice diffusivity models to reactingFoam. Another thread on this is Multi species mass transport library [update] . The code runs well. However, I have no idea how to validate it.
Gaozw is offline   Reply With Quote
Old   July 29, 2018, 22:20
One option could be finding DNS results (eg flame speed data) for which they compute species diffusivity and see how your implementation compares.
Caelan
Old   August 2, 2018, 21:00
Kikuta Enoki
Originally Posted by Gaozw View Post
Hi, foamers,
Hi Gaozw
I have already tried to compile "modifiedReactingFoam" which is indicated in the URL you posted, but couldn't.
is it due to the difference in version of OpenFOAM?
My OpenFOAM is version 4.1.
Which version are you using?
Also, did you compile modifiedReactingFoam without editing anything?
Regards,
Kikuta
Old   August 7, 2018, 00:32
Gao Zhengwei
Hi Kikuta,
I am using OpenFOAM-2.3.1, which matches the author's latest release version. I follow the installation guide and it works fine. It may be incompatible with version-4.1 since there are many differeces between the two versions.
Old   August 7, 2018, 01:25
Gao Zhengwei
Hi clapointe,
Comparing with DNS results is always a good choice. However, it is difficult for me because the diffusivity data in the combustion process can be barely found. I have to compromise and compare the combustion characteristic properties (i.e. flame thickness, flame speed, etc.). Is there a better way?
PS--sorry for the late reply.
material diffusion, openfoam
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
Adding material to CFX material library marlon CFX 2 October 16, 2016 10:33
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
diffusion coefficient mamalili CFX 8 February 24, 2015 17:51
question about how to define diffusion coefficient in CFX rystokes CFX 0 December 12, 2009 06:32
