Lenzo
Rep Power: 12 ![]() |
Hello!
I know this might sound a bit stupid, but, I only find how to transform from stl to openfoam. But do you know how to transform from the file "Points" in the polymesh directory to a object file? Thank you! |
Fumiya Nozaki
Rep Power: 19 ![]() |
You can use the surfaceMeshTriangulate utility.
[Personal]
If you can visualise your case in Paraview you should be able to export to any format that vtk supports, so "stl" is not a big thing
Otavio Duarte Aires Heckler
Rep Power: 9 ![]() |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 07:18 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
