June 8, 2018, 15:11 |
lagrangian submodels conflict
Joaquín Neira
Rep Power: 8 |
I'm working with the intermediate library, trying to use patchInteractionModel and collisionModel, so that particle-particle interaction has a soft sphere treatment (pairSpringSliderDashpot), and the particle-wall interaction has a stick condition. This way, the expected behavior is that the floor is filled with particles and the moving ones bounce on them. It seems like the wallSpringSliderDashpot model overrides the stick condition, and the particles just keep bouncing. Also, there is no 'none' wall model. Code:
standardWallInteractionCoeffs { type stick; // stick, escape e 1; // optional - elasticity coeff mu 0; // optional - restitution coeff } collisionModel pairCollision; pairCollisionCoeffs { maxInteractionDistance 0.00069; writeReferredParticleCloud no; pairModel pairSpringSliderDashpot; pairSpringSliderDashpotCoeffs { // alpha =0.30 para e=0.65 alpha 0.3; //relacionado empiricamente con coef. de rest. b 1.5; //1 para 2D, 1.5 para 3D mu 0.1; // coeficiente de friccion cohesionEnergyDensity 0; collisionResolutionSteps 12; useEquivalentSize no; }; wallModel wallSpringSliderDashpot; wallSpringSliderDashpotCoeffs { // alpha =0.30 para e=0.65 alpha 5.0; //relacionado empiricamente con coef. de rest. b 1.0; //1 para 2D, 1.5 para 3D mu 0.1; // coeficiente de friccion youngsModulus 1e10; poissonsRatio 0.23; cohesionEnergyDensity 0; collisionResolutionSteps 12; useEquivalentSize no; }; } |
June 12, 2021, 15:11 |
Alberta
Did you find any answer to this question? I have a similar problem |
April 26, 2022, 11:15 |
#3 | |
Jonas Görtz
even though your post is old, I might just share my findings on that issue. I ran into the same problem, where the patchInteraction-Model (in my case: escape) was overwritten by the wallSlingSliderDashpot model and the particles simply wouldn't leave my domain. Using two-way coupling, the particles did leave the output as planned. The identification of the problem took me quite some time, but the solution is rather simple: The patch interaction model does only work for patches. If your patch is in constant/boundary difned as a wall, it will be assigned a particle-wall collision when using four way coupling. Since it has overwritten "type: escape" in my case, I guess it will do the same for "type: stick" as in your simulation. Maybe this was/will be helpful to somebody. Cheers Joe |
Aurelia Vallier, MultiScale, Eulerian-Lagrangian Couplling, VOF-LPT, Lagrangian, | saddy | OpenFOAM Programming & Development | 0 | August 9, 2017 14:28 |
Request for Lagrangian Particle Tracking Validation or Verification Paper | Mojtaba.a | OpenFOAM Verification & Validation | 6 | May 23, 2016 01:47 |
converse lagrangian field to eulerian | Jan_B | OpenFOAM Programming & Development | 0 | August 13, 2015 13:11 |
about Lagrangian Multiphase Simulation | jhlee9622 | STAR-CCM+ | 0 | March 18, 2015 01:38 |
subModels in reactingCloud1Properties in fireFOAM | TaylorM | OpenFOAM Running, Solving & CFD | 0 | January 28, 2015 21:38 |
