References for OpenFoam4.x k-epsilon model??
Like Tree1Likes
  • 1 Post By Taataa
Old   May 17, 2018, 12:01
Default References for OpenFoam4.x k-epsilon model??
Sami
Mehrez is on a distinguished road
Hello all,
I'm using OpenFoam v4 and modelling turbulence using k-epsilon model.
Checking the coded k-epsilon equations (https://github.com/OpenFOAM/OpenFOAM...lon/kEpsilon.C), I couldn't find any references in the literature similar to what is implemented.
The form implemented in OpenFoam v4 is different from those I could see on:
- Launder, B. E., & Spalding, D. B. (1974),
- El Tahry, S. H. (1983),
- Rusche H. (2002),
- Behzadi A., (2001 and 2004),
- and in https://www.cfd-online.com/Wiki/Stan...-epsilon_model
Do you have references regarding the OpenFoam v4 k-epsilon model?
Thank you for your help,
mhrz
Mehrez is offline   Reply With Quote
Old   May 17, 2018, 13:29
Taher Chegini
Taataa is on a distinguished road
The official reference are mentioned here.
Taataa is offline   Reply With Quote
Old   May 17, 2018, 13:43
Sami
Thank you for your help.
I have checked these files and, unless I'm wrong, the equations implemented are the ones I'm showing in the attached image. Again, these equations don't correspond to the ones referenced in the file.
Thanks for your time and help.
mhrz
Old   May 18, 2018, 14:20
Sami
Plese share any useful references if you can.
Thank you,
mhrz
Old   May 18, 2018, 19:12
Taher Chegini
k-epsilon implementation? (including volScalarField G)
Mehrez likes this.
Old   May 22, 2018, 09:44
Sami
Thank you for sharing the link.
The code has a little bit changed in version 4 but it's still very useful.
Do you know how source terms "kSource()" and "epsilonSource()" are implemented?
My understanding is that they are used for bubble induced turbulence in the case of two-phase dispersed flow.
Thank you.
mhrz
realizable k epsilon turbulence model errors bexx4444 Main CFD Forum 1 March 21, 2016 03:50
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? JuPa CFX 0 December 22, 2015 06:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 1 December 17, 2000 07:01
