correctBoundaryConditions
Like Tree5Likes
  • 3 Post By mnajafi
  • 2 Post By joshwilliams
Old   May 2, 2018, 20:22
Default correctBoundaryConditions
Mohammad Najafi
mnajafi is on a distinguished road
Hi
1.As I understand, p.correctBoundaryConditions(), updates boundary values after explicit update of p. But p is a volScalarField and it's not defined on the boundaries. So what would be the benefit of this function.
2. In the other hand when I try this I get error.
surfaceScalarField P=fvc::interpolate(p);
P.correctBoundaryConditions();
How should I make the above code work?
Thanks
mnajafi is offline   Reply With Quote
Old   May 2, 2018, 21:11
Mohammad Najafi
1.I found out that it difference is revealed when I call interpolate as code below:
     forAll(p,pi)
        p[pi]=1;
        i++;
    Info<<endl<<"p beofre correct:"<<p<<endl;
    Info<<endl<<fvc::interpolate(p)<<endl;
    p.correctBoundaryConditions();
    Info<<endl<<"p after correct:"<<p<<endl;
2. Apparently functions that are called by correctBoundaryConditions() (like evaluate) are not defined for fvsPatchField and so this function can't be applied for a surfaceScalarField.
bany, Action.Kamen and lpz456 like this.
Old   February 20, 2022, 21:02
Default Correct boundary condition
Anonymous.
gentodin is on a distinguished road
If we cant apply correctBoundaryConditions(); on surfaceScalarField, how do we apply it to correct boundary conditions for surfaceScarlarField at every timestep due to the update of certain variables during parallel simulation?
gentodin is offline   Reply With Quote
Old   September 21, 2022, 06:11
Sreehari Perumanath
sreehahaha is on a distinguished road
Hi gentodin,
Did you find answer to your questions about correcting boundary conditions of a surfaceScalarField using correctBoundaryConditions()? Please let me know. I've been struggling with a similar issue.
Thanks,
S
sreehahaha is offline   Reply With Quote
Old   September 21, 2022, 16:20
Josh Williams
joshwilliams is on a distinguished road
This is fundamentally wrong. In 0/p, you define the internal field and boundary values of p. The boundary values can be found by something like "p.boundaryField()[patchName]".
Hughtong and lpz456 like this.
joshwilliams is offline   Reply With Quote
correctboundaryconditions, geometricfield
