April 16, 2018, 04:42 |
Forcecoeffs Cd = Total or skin
Rep Power: 9 |
H
The Cd that is produced by "forceCoeffs", is the coefficient for total drag (both skin and pressure) or only skin-friction? |
April 17, 2018, 08:19 |
In principle total, but the description on openfoam.com would indicate that the viscous, pressure and porous parts can be obtained separately as well.
This is not found in the openfoam.org description. So it depends on what version you are using. Regards, Tom |
April 17, 2018, 09:41 |
Rep Power: 9 |
Thanks for replying!
I use openFoam 5.0. The variable name I get out is Cd, which I guess indicates that it is total, but I am not sure. edit: I am using openfoam.org's version, so I guess it is total then? |
April 17, 2018, 11:26 |
Yes it is. Regards, Tom |
April 17, 2018, 13:51 |
Rep Power: 9 |
Ok.
Thank you very much for helping! Another question. Do you know if there is some way to obtain the viscous, pressure and porous parts separately in the openfoam.org version? |
April 18, 2018, 03:51 |
Yes, if you use the forces functionObject. That will split it directly in several force and moment vectors in Cartesian coordinates. You would have to get the coefficients yourself based on the correct direction, surface area and velocity reference.
Regards, Tom |
April 18, 2018, 04:25 |
Rep Power: 9 |
Ok. Thanks again!
forcecoeffs |
Segmentation fault (core dumped) | zhoubiao1088 | OpenFOAM Running, Solving & CFD | 4 | March 13, 2017 20:06 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
total mass loss/gain--simulating taylor couette flow | nwpukaka | OpenFOAM Programming & Development | 0 | February 12, 2014 18:57 |
Error in run Batch file | saba1366 | CFX | 4 | February 10, 2013 01:15 |
