defining and using varibales in velocity boundary file
Like Tree1Likes
  • 1 Post By anon_q
Old   April 6, 2018, 14:04
Default defining and using varibales in velocity boundary file
Saideep
Saideep is on a distinguished road
Hi;
I am aware independently of the "partialSlip" and "groovyBC" boundaries.
For my velocity boundary, I would like to use a partialSlip condition like:
wall
type partialSlip;
valueFraction uniform 0.3;
The value fraction is given by: D/(D+2l) where D is the cell size in normal direction and l is the slip length.
However, my cell normal distance is not a constant and varies along the length of the channel. In short, I would like to use groovyBC with the following expression "mag(delta)/(mag(delta)+slip)" where delta is distance between face center on boundary to the cell center.
Unfortunately, this would not capture the tangential component then.
Is it possible to specify variables in the velocity boundary file for "slip=1" and "cellDist=mag(delta)" and use the above mentioned equation?
Saideep is offline   Reply With Quote
Old   April 6, 2018, 15:27
anon_q is on a distinguished road
If I understood you question well, then yes you can use inline calculations (See Section 4.2.13 of the User Guide version 5.0).
Here is an example:
Say I want to calculate a variable
A = A0 * sin(omega * t)
; then
A0     2.0;  //
omega  12.0;
t      7.0;
A    #calc "$A0 * sin($omega * $t)";
Saideep likes this.
anon_q is offline   Reply With Quote
boundary condition u, partial slip, variable definition
