combining parabolic inlet velocity profile with time varying velocity vector values |
March 27, 2018, 02:30 |
Jawahar
Rep Power: 10 |
I have used groovyBC to generate parabolic velocity profile at inlet of a axi-symmetric pipe flow problem. I want the center-line velocity value(magnitude) to change with respect to values read from file.
I have used the groovyBC like this, INLET { type groovyBC; value uniform (1 0 0); variables ( "Vm=2;" "yp=pos().y;" "zp=pos().z;" "r=sqrt(pow(yp,2)+pow(zp,2));" "rmax=max(r);" "a=-Vm/(rmax*rmax);b=Vm;" ); fractionExpression "1"; valueExpression "vector(a*((yp*yp)+(zp*zp))+b,0,0)"; } Here "Vm" is the magnitude of the velocity profile. this has to change every time step. time=0.001 Vm=0.34 time=0.002 Vm=0.45 time=0.003 Vm=0.38 time=0.004 Vm=0.40 ... ... ... ... time=0.8 Vm=0.24 Any possibility of implementing this in groovyBC.? or can we write a separate boundary condition file for this.? I am new to OpenFoam. |
June 1, 2018, 18:38 |
Faiaz Khaled
Rep Power: 9 |
Dear Jawahar,
I have a similar question to this. Were to able to generate velocity profile varying with time at the inlet? Please let me know. Thank you. Regards, Faiaz |
June 2, 2018, 18:52 |
anonymous
Rep Power: 14 |
Hi!
Honestly i'm not familiar with groovyBC, but i think you can use codedFixedValueFvPatchField: https://cpp.openfoam.org/v5/classFoa...d.html#details I have never tried to use this BC with interpolation table from a file, but you can include libs and header files so I think you can use it with a little coding if you don't want to write a new BC and compile it and etc... |
July 10, 2023, 06:41 |
#4 | |
Brahim Aly
Hello Faiaz, I'm really curious if you had some keys to solve your problem. Actually I'm working on the same problem. My geometry is a T junction with two inlets and I want to have a door function for the maximum velocity that goes from 0 to 1 every 10 time steps. As for the profile of the velocity it should be parabolic. I have used groovyBC, codedFixedValue and created my own boundary condition. I failed in each of them. groovyBc: It did great with sine function and i had the pulse that I wanted but I struggled to do a ramp. codedFixedValue: It worked as fine as it can gets with the ramp and the parabolization for geometries that are created in blockMesh. But when it came to apply it on my T junction that i imported from Salome, the parablozation don't work no more; I do my parabolization with a loop over all inlets patches. MyParabolicV (personnal BC): I struggle implementing the time loop to do the ramp. Would appreciate any help or pointer, BABY FOAMER, Brahim. |
groovybc, time vayring bc, unsteady b.c. |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 05:58 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
Time varying parabolic velocity | fcortes | OpenFOAM Running, Solving & CFD | 2 | September 29, 2010 02:43 |
time varying inlet velocity | Zhe Liu | CFX | 0 | July 31, 2008 07:56 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
