wmake error: SourceFiles could not be created in user home
Like Tree1Likes
  • 1 Post By JackJohnson
Old   February 20, 2018, 08:00
Default wmake error: SourceFiles could not be created in user home
Jack
JackJohnson is on a distinguished road
Hi all,
I am new completing some University work on OpenFOAM and I'm still very new to the programme. I am using Bash on Ubuntu on Windows.
Whilst trying to modify the SimpleFoam solver, I am unable to create a copy of the solver in my $WM_PROJECT_USER_DIR.
When I execute the wmake command, I get the following error message:
/opt/openfoam5/wmake/wmake: line 409: make: command not found
/opt/openfoam5/wmake/wmake: line 412: make: command not found
wmake error: file 'Make/linux64GccDPInt32Opt/sourceFiles' could not be created in /home/Matt-ts/OpenFOAM/Matt-ts-5.0/applications/simpleFoamDev
Here are the steps I have successfully completed thus far:
1). Copy simpleFoam solver to WM_PROJECT_USER_DIR/applications
2). Rename simpleFoam to which I have called it simpleFoamDev
3). Rename source code file simpleFoam.C to simpleFoamDev.C
4). edit files file within the make folder to read:
SimpleFoamDev.C
EXE = $(FOAM_USER_APPBIN)/simpleFoamDev
5). Within simpleFoamDev folder execute commands:
wclean
wmake
I have followed the instructions as per the following guide which was alluded to in previous posts:
http://www.cloudpyme.eu/wp-content/u...on4-Slides.pdf
Any suggestions on what the issue may be would be gratefully received, thanks in advance!
JackJohnson is offline   Reply With Quote
Old   February 21, 2018, 10:02
Jack
Turns out I didn't have the make package installed on my version of OpenFoam as solved in this other thread:
Apologies for the double post, would delete this repeat if I knew how...
Paul George likes this.
openfoam, simplefoam, source file, wmake, wmake error
Wmake as User sven82 OpenFOAM Installation 3 August 14, 2013 04:23
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 19:37
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
CFX 10 User Routine NOT in Fortran Andre CFX 14 August 9, 2006 00:03
UDF with user created surfaces Henry Lee FLUENT 2 March 23, 2006 04:24
