How to set up for KomegaSSTLM turbulence to plot wallshearstress
Like Tree1Likes
  • 1 Post By ht2017
Old   January 25, 2018, 00:39
Default How to set up for KomegaSSTLM turbulence to plot wallshearstress
ESI
ht2017 is on a distinguished road
Hi everyone,
I am using KomegaSSTLM for my simulation. But I don't know the reason why my result incorrect?
this is my case:
I run the simulation for A-airfoil with inlet condition is M = 0.15,Re = 2.1e6, alpha =13.1,Tu = 0.1%,μ_t/μ =2.
I calculate the coefficients:
K =3/2(UI)^2 = 3/2 (51.9*0.1%)^2=0.00404; ω = ρ* k/μ*(μ_t/μ)^-1
ω = 1.225*0.00404/(1.846*10^-5)*(2)^-1=134.05;
gamma I choose 1. gama = 1;
Re_thetat = (1173.51-589.428*Tu+0.2196/(Tu^2))*F(λθ) Tu<= 1.3;
Re_thetat = 331.50*(Tu-0.5658)^-0.671*F(λθ) Tu >1.3;
F(λθ) =1-1(-12.986*λθ-123.66*λθ^2-405.689*λθ^3)*e^(Tu/1.5)^1.5 λθ<=0;
F(λθ) =1+0.275*(1-e^(-35.*λθ))*e^(Tu/0.5) λθ>0;
From this function: I choose λθ = 0 ( I not sure it is correct I only think Du/Ds = 0 Inferred λθ = 0) then I calculate Re_thetat = 1.365e+3.
I have the coefficients:
K =0.00404;ω =134.05,gamma = 1,Re_theta = 1.365e+3 this is the coefficient value for inlet condition.
And Then I set up following the tutorial incompressible/simpleFoam/T3A. I change the geometry to A-airfoil and set up the value coefficient and I run it.
The finally, I run with comment line "simpleFoam -postProcess -func 'wallShearStress' and paraFoam. In the paraview I load out the data in the surface top-Airfoil. I plot the wallshearstress following the x-axis. But my result incorrect.
If anyone has experienced run with KomegaSSTLM for airfoil Please teache me. I really hope anyone who can help me resolve it.
Thank you very much
wht likes this.
ht2017 is offline   Reply With Quote
how to set URANS turbulence model in unsteady flow simulation TimLiu OpenFOAM Pre-Processing 0 April 25, 2017 09:52
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 16:40
How to set boundary conditions for \tilde{nu} for SA turbulence model? PierluigiRossi SU2 3 May 12, 2015 15:16
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 20:51
