3D cylinder problem
Like Tree1Likes
  • 1 Post By Saideep
Old   November 21, 2017, 16:30
Default 3D cylinder problem
Ajay
vkannama is on a distinguished road
Dear all,
I am new to openfoam and trying to solve a simple 3D cylinder laminar flow problem. I obtained the geometry from Cylinder mesh using blockMesh with m4 macro and, using paraview, everything is good with geometry. The BCs are: inlet velocity is 1m/s and outlet pressure is 0. I earlier solved this problem in Nek5000 and both the velocity and pressure-drop matches with the theoretical values. However, in openfoam, the velocities and pressure are both strange. For example, the axial pressure drop is supposed to be linear, while my result is shown attached.
Please point any mistakes from the relevant input files pasted below, or anything else I might be doing. I will be grateful.
Thanks,
Ajay
******** controlDict file ******
application icoFoam;
deltaT 0.005;
******** fvSolution ******
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-07;
relTol 0;
pFinal
$p;
relTol 0;
U
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-07;
relTol 0;
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
******** velocity BC/IC (U) ******
dimensions [0 1 -1 0 0 0 0];
internalField uniform (1 0 0);
boundaryField
inlet
type fixedValue;
value uniform (1 0 0);
walls
type noSlip;
outlet
type zeroGradient;
******** pressure BC/IC (p) ******
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
walls
type zeroGradient;
vkannama is offline   Reply With Quote
Old   November 22, 2017, 09:46
Garet Potu
Gret is on a distinguished road
I have the same problem
Gret is offline   Reply With Quote
Old   November 22, 2017, 09:53
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Could you elaborate? Basic question is "Why icoFoam?"
alexeym is offline   Reply With Quote
Old   November 22, 2017, 11:14
Saideep
Saideep is on a distinguished road
Hi;
I did not use blockmesh but generated an .stl and ran my simulations using icoFoam and I get reasonable results.
1. I am not sure if 'noSlip' is a keyword added to latest versions of OpenFOAM but you can replace it with
wall
type fixedValue;
value uniform (0 0 0);
2. I guess the time step size is quite high. Try with 5e-7.
3. If possible try to refine your mesh. The finer it is, I see the results converge better to reality.
Let me know if you want my case file. I will drop it.
Saideep is offline   Reply With Quote
Old   November 22, 2017, 11:24
Saideep
Found my case easier. Attached the case.
Just run:
1. surfaceFeatureExtract
2. blockMesh
3. snappyHexMesh -overwrite
4. icoFoam
vkannama likes this.
Old   November 22, 2017, 14:02
Ajay
Just run:
2. blockMesh
4. icoFoam
Hi Saideep, this worked very nicely! I see a parabolic velocity profile and linear pressure drop. Don't really understand the steps you've written. I will get back to you if I have any trouble. Thank you.
Originally Posted by alexeym View Post
Hi Alex, I thought icoFoam is the simplest solver for my purpose (laminar, not steady state). Are there any alternatives? Please let me know. Would like to try others.
openfoam
Dynamic Structured mesh around cylinder problem!!! ludosbiz Mesh Generation & Pre-Processing 2 March 23, 2016 16:15
Problem of convergence- simulation of flow wind around cylinder activo FLUENT 6 October 23, 2015 02:57
problem of the drag's convergence for a circular cylinder with a synthetic jet (udf) bia FLUENT 0 February 17, 2015 12:06
Problem solving a cylinder case 2d. Simple Foam vbesteban OpenFOAM Running, Solving & CFD 0 October 16, 2014 17:51
solving airfoil like square cylinder problem? zonexo Main CFD Forum 1 May 27, 2006 16:16
