Question about Plotting Vapor Penetration Length
Like Tree1Likes
  • 1 Post By asakusa
Old   October 30, 2017, 05:31
Question Question about Plotting Vapor Penetration Length
FengHaifeng
asakusa is on a distinguished road
Hello!
I'm a beginner of OpenFOAM and I'm using sprayFoam(in OF4.1). I need to plot the liquid penetration length and vapor penetration length, comparing to the standard result to check if my model is correct. Liquid penetration length can be calculated by the function penetration.(fraction)(the pretty standard of fraction for liquid penetration is 0.95), as the following code in SprayCloud.C:
template<class CloudType>
void Foam::SprayCloud<CloudType>::info()
CloudType::info();
scalar d32 = 1.0e+6*this->Dij(3, 2);
scalar d10 = 1.0e+6*this->Dij(1, 0);
scalar dMax = 1.0e+6*this->Dmax();
scalar pen = this->penetration(0.95);
Info << " D10, D32, Dmax (mu) = " << d10 << ", " << d32
<< ", " << dMax << nl
<< " Liquid penetration 95% mass (m) = " << pen << endl;
But how can I calculate the vapor penetration of every time step? Should I still use this function? Thank you in advance.
asakusa is offline   Reply With Quote
Old   August 18, 2020, 10:24
rmn
Roman Reinhardt
rmn is on a distinguished road
Hi asakusa,
have you found a solution back then?
I am at the same point as you have been.
I also struggle to identify which files and entries from the time directories I have to use for the plot.
I hope you (or anybody else) will still see this.
Thank you so much in advance.
Greetings
rmn is offline   Reply With Quote
sprayfoam, vapor penetration
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) Scabbard OpenFOAM Running, Solving & CFD 1 July 22, 2014 05:50
Quick Reference Value Question (Length) kyles.sverige FLUENT 0 May 9, 2014 16:54
Integral Length Scale vs Turbulent Length Scale Scott Nordsen FLUENT 2 January 20, 2014 02:17
Cases with small length scale work fine on a single processor but fail in parallel adona058 OpenFOAM Bugs 5 April 17, 2009 05:41
Characteristic Length Scale Thomas P. Abraham Main CFD Forum 2 April 20, 1999 18:16
