Negative Temperature chtMultiRegionSimpleFoam + thermalBaffle1D + Radiation
Like Tree2Likes
  • 2 Post By jaydeep
Old   October 21, 2017, 01:10
Exclamation Negative Temperature chtMultiRegionSimpleFoam + thermalBaffle1D + Radiation
Jaydeep
jaydeep is on a distinguished road
Hello everyone,
I pieced together stuff from the generous help from Tobias and Alex to create a test case. It is a very simple problem where you have 2 solids (isotropic), in air. There is a vertical wall next to the second solid, created as thermalBaffle1D.
Everything works fine until you introduce baffle. After adding baffle, the temperature in the baffle goes negative (reduces below ref value and indefinitely reduces until simulation crashes). I don't know what is exactly happening here.
While testing for radiation, I discovered that in openfoam-dev "qr" option in baffle boundary doesn't affect anything? It still has to be specified as "Qr".
@Tobi @zfaraday - you will probably have an answer to this question - this example borrows stuff from your axisymmetric meshing and circuitBoardCooling_rad tutorials respectively. Many thanks!
jaydeep is offline   Reply With Quote
Old   October 21, 2017, 02:01
Default Updates
Jaydeep
Please note that createBaffles need to be run separately. There's an error in nut patch entry for baffles -- remove compressible::
Old   October 21, 2017, 02:20
Default snGrad scheme
Jaydeep
Note:
I suspected for a while using uncorrected scheme for sngrad in solid regions could be a reason. Changed it to corrected -- negative temperature seems to have gone away. I will confirm full resolution tomorrow.
Old   October 21, 2017, 02:38
Jaydeep
Problem solved.
It was snGrad scheme in fact.
student666 and Ramzy1990 like this.
Old   November 23, 2017, 20:48
Franco
fracasce is on a distinguished road
Thank you for your post! I don't know if this could be helpful, but I'd like to add that from OF4.1 to OF5.0, the developers changed the variable Qr (OF4) to qr (OF5).
fracasce is offline   Reply With Quote
baffles, chtmultiregionsimplefoam, heat and mass transfer, radiation model
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 06:56
