Stefan Problem : Tin Melting : Moving Boundary
Like Tree1Likes
  • 1 Post By swparth
Old   September 21, 2017, 15:53
Default Stefan Problem : Tin Melting : Moving Boundary
parth swaroop
swparth is on a distinguished road
I wish to solve stefan problem ( melting of solid substance) along with convection in fluid domain. Initially I started with COMSOL Multiphysics and as an example you can refer to this simulation in this link.
The physics of the problem is as follows : A square cavity contains both solid (right domain) and liquid tin (left domain). The maximum possible temperature of the solid tin can be its melting temperature and hence the interface is fixed at this temperature. There exist a temperature difference between left and right boundaries such that solid tin will start melting. This velocity/movement melting interface is captured by an energy balance equation. In COMSOL, with this, it is possible to estimate the movement of the mesh using the same equation.
But I wish to switch to OPENFOAM. Hence, I would like to know what is the best approach to model this problem using OPENFOAM?
Thank you for your time and patience.
Regards
Parth
ALiSafari likes this.
swparth is offline   Reply With Quote
Moving boundary problem based on calculated data sandro.grm OpenFOAM Programming & Development 53 October 11, 2024 09:50
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
