August 23, 2017, 07:59 |
Specific cell volume in paraview
Katt
Rep Power: 9 |
I would like to select a specific cell using "SelectionDisplay Inspector" in paraview and would like to know the volume/ area of the selected cell in 2D/ 3D respectively. I tried the intergrate Variable but it gives the entire volume of the domian rather than cell volume. Can anyone help me here. K |
August 23, 2017, 09:12 |
Katt
Rep Power: 9 |
Apologies;
Found the solution here using "Python Calculator" https://www.paraview.org/Wiki/Python...ammable_filter |
January 14, 2019, 08:29 |
Ruchit Patel
Rep Power: 8 |
Hi Katt..
I want to calculate the area of all control volume of Inlet patch as shown in attachments. Can you please enlighten me how can i calculate these areas using python calculator and also tell me about python calculator like installation and usage. Is it directly available in paraview ? Thanks and Regards, Ruchit Patel |
July 3, 2021, 08:02 |
Volume option in MeshQuality Filter
Sourav Mandal
Rep Power: 7 |
In addition to the python calculator as mentioned by Katt in this thread,
The Filters > MeshQuality also returns same result. Use the Volume dropdown option in Hex Quality Measure or Tet Quality Measure in the properties window of the filter. CAVEAT: If the mesh is composed of both hex and tetrahedrons, then I am not sure if it works... |
March 18, 2022, 15:32 |
qutadah
Rep Power: 5 |
this gives me a syntax error..... here is a screenshot...
also I need to extract another ratio from the cell volumes, how can I do that? I used calculator but the array is not there... Only Vc array is there... |
March 28, 2022, 06:02 |
Jan
Rep Power: 20 |
the Filter "Cell Size" calculates the cell volume. Same filter can be used for getting the area in case of a surface as input. Best, Jan |
November 16, 2023, 10:16 |
Marķa Rosales
Rep Power: 3 |
Hello community,
this may work for someone: 1) using topoSet and foamToVTK extract as vtm series the region 2) import it into paraview and apply filter cell size 3) open spreadsheet and check both Cell Data and Field Data. The first one shows volume per cell, the last one shows the total volume of the vtm series. |
cell volume, paraview |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
