ElmerFoamFSI parallel error
Like Tree2Likes
  • 1 Post By Thaw Tar
Old   August 21, 2017, 03:13
Smile ElmerFoamFSI parallel error
Thaw Tar's Avatar
Thaw Tar
Thaw Tar is on a distinguished road
I am not very sure that my post is directly related to OpenFOAM but I would be very grateful if anyone could help me.
I want to do FSI with large deformations and chose ElmerFoamFSI for my research.
ElmerFoamFSi is a package intended to solve fluid-structure interaction problems using OpenFOAM and Elmer. It couples foam-extend 3.2 and Elmer 8.0 by something called IMPACT coupler (I don't know the details).
I could compile ElmerFoamFSI with the default BuildSourceScript file and I could run the test cases such as SimpleDynamic and HronTurek FSI3 cases using a single thread.
However, when I try to run in parallel using "elmerfoamfsiPar" solver using "elmerfoamfsiPar test.config" I got the following message:
elmerfoamfsiPar:Run: User Parameters:
elmerfoamfsiPar:Run: FluidSolver = OpenFoamFSI
elmerfoamfsiPar:Run: SolidSolver = ElmerCSC
elmerfoamfsiPar:Run: TransferService = SurfX
elmerfoamfsiPar:Run: FinalTime = 1.0
elmerfoamfsiPar:Run: TimeStep = 1.0e-3
FsiFoam:Load: Loading FsiFoamModule with name FluidsComponentInterface.
Loading ElmerCSC: StructuresComponentInterface
elmerfoamfsiPar:fsicouplingpar:Initialize: Final Time = 1
elmerfoamfsiPar:fsicouplingpar:Initialize: Time Step = 0.001
OF Module verbosity = 1
Calling MPI_Init or MPI_Init_thread twice is erroneous.
[thawtar-Workstation:8494] *** An error occurred in MPI_Init
[thawtar-Workstation:8494] *** on communicator MPI_COMM_WORLD
[thawtar-Workstation:8494] *** MPI_ERR_OTHER: known error not in list
[thawtar-Workstation:8494] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
I think my OpenMPI interface is working well because I can run foam-extend-3.2 cases in parallel well.
I do not know how to fix this error. I would be very grateful if you can help me solve this problem.
elvis likes this.
Thaw Tar is offline   Reply With Quote
Old   September 10, 2017, 09:38
Wink Solved that part
Thaw Tar's Avatar
Thaw Tar
It was my stupid mistake.
I tried serial solver using
"mpirun -np 4 elmerfoamfsi test.cfg" and it did not work because it was intended for only serial computation.
The parallel version is elmerfoamfsiPar and it needs mpirun.
So, I tried
"mpirun -np 4 elmerfoamfsiPar test.cfg"
And it works!!
Cheers!
elvis likes this.
Old   October 30, 2017, 17:46
Shyam Sunder
ssyadav is on a distinguished road
Hello Tar
I ran the parallel case as you described, but still i am getting MPI error.
Following is what I did and what I am getting:
mpirun -np 2 elmerfoamfsiPar test.config
elmerfoamfsiPar:Run: FinalTime = 0.05
elmerfoamfsiPar:Run: TimeStep = 5.0e-4
elmerfoamfsiPar:fsicouplingpar:Initialize: Final Time = 0.05
elmerfoamfsiPar:fsicouplingpar:Initialize: Time Step = 0.0005
[cfd2:27055] *** An error occurred in MPI_Init
[cfd2:27055] *** reported by process [139957580988417,139955804307457]
[cfd2:27055] *** on communicator MPI_COMM_WORLD
[cfd2:27055] *** MPI_ERR_OTHER: known error not in list
[cfd2:27055] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[cfd2:27055] *** and potentially your MPI job)
I have decomposed the case using AllrunPar. Any clue what I am missing?
Thanks
Shyam
ssyadav is offline   Reply With Quote
Old   October 30, 2017, 18:41
Thaw Tar's Avatar
Thaw Tar
I can see you use 2 processors. So, I think you decomposed into 2 domains in Open Foam.
But how about Elmer? Did you use the version for 2 processors ? May be you need 2 processors version of Elmer grid (I mean, the script for grid generation for Elmer).
Old   November 3, 2017, 13:25
Default Parallel ElmerFoamFSI
Shyam Sunder
Hello Tar
Can you please help me in how to prepare the parallel ElmerFoamFSI case?
Where I can further information on this?
I am using the following commands but still getting error:
1) Run the script AllrunParDrvSetup
2) cd fluid
3) ElmerGrid 1 2 beam3d -partition 4 1 1 0
4) mpirun -np 4 elmerfoamfsiPar test.config
The test case I am trying is located in
ElmerFoamFSI/testing/share/Testing/test_data/HronTurekFSI3_136/
Thanks
Shyam
elmerfoamfsi, mpi_init, openfoam fsi
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 21:16
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
