something wrong when i set the boundary file.
Like Tree1Likes
  • 1 Post By alexeym
Old   July 8, 2017, 01:34
Default something wrong when i set the boundary file.
Liwei Zhang
zlw306 is on a distinguished road
i'm running a propeller simulation using pimpledymfoam.below are my steps:
1.I create two mesh name rotor and body,and i use fluent3DMeshToFoam separately to convert them to openfoam.
2.then i use mergeMeshes to combing the two meshes.
3.I copy the new mesh to a new folder ,and use splitMeshToRegions -makeCellZones -overwrite to create a cell zone.
Until now ,it all seems well,i can use the checkMesh command.
Then after edit the polyMesh/boundary to add AMI patches ,the i use checkMesh:
| \\ / O peration | Version: 4.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.x
Exec : checkMesh
Date : Jul 08 2017
Time : 12:32:17
Host : "zlw"
PID : 4660
Case : /home/zlw/OpenFOAM/zlw-4.x/30x/prp/c
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
--> FOAM Warning :
From function entry::getKeyword(keyType&, Istream&)
in file db/dictionary/entry/entryIO.C at line 80
Reading /home/zlw/OpenFOAM/zlw-4.x/30x/prp/c/constant/polyMesh/boundary
found on line 85 the punctuation token ')'
expected either } or EOF
--> FOAM FATAL IO ERROR:
Expected a ')' or a '}' while reading PtrList, found on line 89 an error
file: /home/zlw/OpenFOAM/zlw-4.x/30x/prp/c/constant/polyMesh/boundary at line 89.
From function char Foam::Istream::readEndList(const char*)
in file db/IOstreams/IOstreams/Istream.C at line 155.
FOAM exiting
and below is my boundary file:
FoamFile
version 2.0;
format binary;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
8
OUTTER
type cyclicAMI;
nFaces 27322;
startFace 2470870;
matchTolerance 0.0001
neighbourPatch INNER
transform noOrdering
INLET
type patch;
nFaces 1279;
startFace 2498192;
OUTLET
type patch;
nFaces 1317;
startFace 2499471;
FAR
type wall;
inGroups 1(wall);
nFaces 8812;
startFace 2500788;
INNER
type cyclicAMI;
nFaces 38366;
startFace 2509600;
neighbourPatch OUTTER
BLADE
type wall;
inGroups 1(wall);
nFaces 42390;
startFace 2547966;
YESHAO
type wall;
inGroups 1(wall);
nFaces 253;
startFace 2590356;
HUB
type wall;
inGroups 1(wall);
nFaces 6093;
startFace 2590609;
I really appreciate someone can help me out !THANKS
zlw306 is offline   Reply With Quote
Old   July 8, 2017, 17:34
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
For some reason your cyclicAMI patches descriptions miss ; at certain line ends. For example:
OUTTER
type cyclicAMI;
nFaces 27322;
startFace 2470870;
should be
OUTTER
type cyclicAMI;
nFaces 27322;
startFace 2470870;
matchTolerance 0.0001;
neighbourPatch INNER;
transform noOrdering;
Do not know why this happens.
alexeym is offline   Reply With Quote
Old   July 9, 2017, 03:37
Liwei Zhang
Originally Posted by alexeym View Post
OUTTER
type cyclicAMI;
nFaces 27322;
startFace 2470870;
should be
OUTTER
type cyclicAMI;
nFaces 27322;
startFace 2470870;
Thanyou very much for your reply.I add ; as you said.But the same error happens again.i have cheked boundary file,there is not any 89 line and i think brackets are ok. Do you have any idea of what the problem is.Best regard!
Sent from my iPhone using CFD Online Forum mobile app
Old   July 9, 2017, 06:05
Alexey Matveichev
Did you add ; to all cyclicAMI dictionaries or just one I have mentioned? Can you post your new boundary file (in CODE tag)?
Alisa_W likes this.
Old   July 9, 2017, 07:11
Liwei Zhang
Oh.i did lost a ; now it is ok.it'a stupid mistake. Thank you for your kindness and patience!!!
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
