Procedure for modifying a solver: Beginner's Question
Like Tree3Likes
  • 1 Post By tzaht
  • 2 Post By floquation
Old   June 9, 2017, 07:24
Default Procedure for modifying a solver: Beginner's Question
Tony Zahtila
tzaht is on a distinguished road
I am trying to learn the framework of OpenFoam so that I can edit the equations that are being solved.
As a starting point for my learning, I am trying to edit the laplacianFoam solver to add a source term. If I succeed in adding a large source term, the basic/laplacianFoam/flange should blow up, proving I'm editing the correct file.
I have edited the file in:
applications/solvers/basic/laplacianFoam/laplacianFoam.C
However, this does not change the solution. Anybody able to shed some light or point me to a good guide on this?
Regards.
Svetlana likes this.
tzaht is offline   Reply With Quote
Old   June 9, 2017, 07:34
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Did you compile your changes?
Try this tutorial:
https://github.com/UnnamedMoose/Basi...mmingTutorials
Svetlana and random_ran like this.
floquation is offline   Reply With Quote
Old   June 15, 2017, 12:41
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Check out my screencasts for further I information. But I guess floquation gave the correct answer
Sent from my HTC One mini using CFD Online Forum mobile app
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   June 15, 2017, 23:00
Tony Zahtila
Thanks floquation and Tobias.
Yes, I simply wasn't compiling. :facepalm: I'm a bit embarrassed to waste your time on something so simple.
I appreciate your help, I am used to the MATLAB environment where you don't compile.
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Question abt. the Riemann analytic solver jinwon Main CFD Forum 0 July 16, 2007 15:11
A beginners question Pst Main CFD Forum 2 February 19, 2006 04:33
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 05:37
A Question on the Dynamic procedure in LES dragon Main CFD Forum 1 April 28, 2005 16:11
