Import Mesh to OpenFoam
Like Tree1Likes
  • 1 Post By richardlee1206
Old   June 2, 2017, 17:45
Default Import Mesh to OpenFoam
Ang Li
richardlee1206 is on a distinguished road
Hi all,
I am a beginner of OpenFoam, and I met a problem about importing mesh. I generated a mesh of cyclorotor in ICEM, and exported a .msh file. Then, I imported the mesh to OpenFoam, but it said INTERFACE is internal to the mesh and is not being added to the boundary. And in the boundary file, all interfaces boundaries were added to a patch named default wall. So how can separate these boundaries and define them as interface?
The mesh is attached.
Thanks in advance.
Ang
richardlee1206 is offline   Reply With Quote
Old   June 6, 2017, 12:55
Joachim Herb
jherb is on a distinguished road
Did you give the different boundaries different names in ICEMCFD. Also do they belong to different 2D (shell) meshes?
Is that INTERFACE really an internal mesh? Does it actually consist of two 2D meshes in ICEMCFD? If yes you can merge the (2D) nodes of the two 2D meshes in ICEMCFD. Then you should be able to remove that 2D mesh there.
What does the ICEMCFD mesh checks say?
jherb is offline   Reply With Quote
Old   June 7, 2017, 17:02
Ang Li
Hi Joachim,
My problem has been solved. I defined all boundaries as wall in ICEM, and I imported the mesh to OpenFoam successfully. Then, I changed the boundary conditions of interface in OpenFoam.
Also thanks for your advice.
Ang
mounyz likes this.
[Other] import mesh to OpenFOAM rpienika OpenFOAM Meshing & Mesh Conversion 0 October 11, 2013 16:24
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[ANSYS Meshing] Import Mesh from CFX-Solve to OpenFOAM A.Stamatopol ANSYS Meshing & Geometry 1 July 25, 2013 12:08
Did anyone worked on GID mesh import in OpenFoam?? Tushar@cfd OpenFOAM 2 May 31, 2011 13:01
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
