OpenFOAM Screencast - How to program with OpenFOAM
Like Tree24Likes
  • 15 Post By Tobi
  • 5 Post By nsf
  • 1 Post By Tobi
  • 3 Post By Tobi
Old   March 19, 2017, 06:40
Default OpenFOAM Screencast - How to program with OpenFOAM
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hello everybody,
based on the survey I made on my website, the wish of the community was to create a new session of screencasts that show how to program in OpenFOAM. Therefore, I started to create new videos which can be checked out in the link below. During the screencasts I am trying to talk about the following things:
  • Recommended system set-up for development (not necessary but very useful)
  • Creating a new solver (cavitatingFoam into boilingFoam)
    • Preparing the new solver
    • Analyzing the files/structure of the solver
    • Talking about different objects and the usage of Doxygen
    • Changing the corresponding solver in order to simulate boiling
  • Set-up of a simple test case
  • Talking about gdb and the usage
The videos can be found here: Screencasts about programming in OpenFOAM
nsf, JonW, likres and 12 others like this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   March 20, 2017, 15:54
nsf
Nicolas Edh
nsf is on a distinguished road
Hi Tobi,
Yet another great screen cast. Really good work!
I'm sure you had a good reason to copy OpenFOAM-dev and ThirdParty-dev to a separate folder for the debug version. For others who are starting programming with OpenFOAM:
You can also just set the environment variable WM_COMPILE_OPTION as an argument to etc/bascrc.
I've set two aliases in my $HOME/.bashrc like so:
OFINSTDIR=/path/to/somehere/OpenFOAM
alias ofdbg=". $OFINSTDIR/OpenFOAM-dev/etc/bashrc WM_COMPILE_OPTION=Debug"
alias of=". $OFINSTDIR/OpenFOAM-dev/etc/bashrc"
In order to compile the debug version I just have to run the alias "ofdbg", i.e.
ofdbg
cd $WM_PROJECT_DIR
./Allwmake
If everything is correctly setup, things should run smoothly. OpenFOAM doesn't overwrite anything. The debug version of the compiled libraries are found under $WM_PROJECT_DIR/platforms/*Debug
Keep up the good work Tobi!
P.s
I really like QtCreator, it's got a built in debugger and has smart auto-completion. Here's how to set it up for OpenFOAM
https://openfoamwiki.net/index.php/H...with_QtCreator
Tobi, rajibroy, kera and 2 others like this.
nsf is offline   Reply With Quote
Old   March 20, 2017, 17:13
Tobi's Avatar
Tobias Holzmann
Great. I will mention your stuff in the next screencast or will add another inbetween. You are right, I just wanted to keep everything separated
Thank you for the hint and your Feedback.
Sent from my HTC One mini using CFD Online Forum mobile app
nsf likes this.
Keep foaming,
Tobias Holzmann
Old   May 29, 2017, 04:46
Tobi's Avatar
Tobias Holzmann
Hi all,
last week I finished the project about the screencasts in the topic »developement in FOAM«. For some reason I choose the wrong solver at the beginning but that is not a big deal. I guess most people are just interested in the last video 5.6. Here I made a power-screencast in which I build the complete solver + some tutorial.
Have fun and maybe someone get something new out of it.
nsf, rajibroy and sungda like this.
Keep foaming,
Tobias Holzmann
doxygen, gdb, holzmann cfd, openfoam programming, tobias holzmann
OpenFOAM Training Beijing 22-26 Aug 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 May 3, 2016 05:57
which program is suitable for showing different graphs into one to compare? immortality OpenFOAM Post-Processing 4 April 26, 2013 23:22
Call Fortran program from OpenFoam tsjb00 OpenFOAM Running, Solving & CFD 6 April 22, 2013 16:26
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
