Problem running potentialFoam
Like Tree1Likes
  • 1 Post By Antimony
Old   March 3, 2017, 07:22
Default Problem running potentialFoam
IvánFB
ivanfb95 is on a distinguished road
I have a problem trying to running potencialFoam in OpenFoam 4.1
First I had run decomposePar (8 subdomains)
Then I want to run: potentialFoam 8 -noFunctionObjects
The following error is displayed:
Usage: potentialFoam [OPTIONS]
options:
-case <dir> specify alternate case directory, default is the cwd
-initialiseUBCs Initialise U boundary conditions
-noFunctionObjects
do not execute functionObjects
-pName <pName> Name of the pressure field
-parallel run in parallel
-roots <(dir1 .. dirN)>
slave root directories for distributed running
-withFunctionObjects
-writePhi Write the velocity potential field
-writep Calculate and write the pressure field
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
Using: OpenFOAM-4.1 (see www.OpenFOAM.org)
Build: 4.1
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 1
FOAM exiting
Can anybody help me?
Thanks.
ivanfb95 is offline   Reply With Quote
Old   March 5, 2017, 23:21
Antimony is on a distinguished road
The syntax to run in parallel is:
mpirun -np <number of processors> <solver/utility name> <options for solver/utility>
In your case, you should have put it as:
mpirun -np 8 potentialFoam -noFunctionObjects
Source: https://cfd.direct/openfoam/user-gui...x7-630002.3.11
Cheers,
Antimony
ivanfb95 likes this.
Antimony is offline   Reply With Quote
Old   March 6, 2017, 05:13
IvánFB
Thanks for your help
The error has been solved.
Problem About Running Fluent In Linux mitra FLUENT 18 June 20, 2019 03:11
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 14:30
[Other] Problem running after decomposition paul.m.edwards OpenFOAM Meshing & Mesh Conversion 0 January 14, 2015 13:55
Problem while running in Highperformance computing environment Phanipavan STAR-CD 1 September 11, 2013 07:42
problem with running in parallel dhruv OpenFOAM 3 November 25, 2011 06:06
