errors after running (wmake ) command, please help!!
Like Tree2Likes
  • 1 Post By Salim
  • 1 Post By risku9
Old   January 30, 2017, 21:39
Exclamation errors after running (wmake ) command, please help!!
Salim
Salim is on a distinguished road
hi guys,
I am currently working in an Airfoil case using OpenFoam 2.3 version. I have achieved this so far: (the case files)
http://www.tfd.chalmers.se/~hani/kur...bedi/files.tgz
but I am still encountering some issues related to compiling four new (modified) turbulence models from SpalartAllmaras which are as follow:
1. mySpalartAllmaras
2. myZoneSpalartAllmaras
3. myAlphaPdcSpalartAllmaras
4. myPdcSpalartAllmaras
I need to solve the issues in order to run a SimpleFoam according to this tutorial:
http://www.tfd.chalmers.se/~hani/kur...ort_task_3.pdf
the problem is when I try to compile the turbulence models
using the command in terminal (wmake ) I got this error:
the error appears in the red colour for all 4 cases mentioned above.
while at the bottom of the same error message I got this .
bear in mind that I already have add the a line to the controlDict such as
libs ("libmyIncompressibleTurbulenceModels.so"); (you can check the link above )
- Do you think the problem is because the current version of OpenFoam2.3 that am using???
please help me I am stuck
thanks a lot,
Salim
raj kumar saini likes this.
Salim is offline   Reply With Quote
Old   February 7, 2017, 22:06
Clara
risku9 is on a distinguished road
Hi Salim,
The compressed files in the link (http://www.tfd.chalmers.se/~hani/kur...bedi/files.tgz) aren't available. Without looking at them it is a bit tricky to help you!
Regards
risku9 is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
