pitzDailyMapped killing fluctuations
Like Tree1Likes
  • 1 Post By juho
Old   December 30, 2016, 14:12
Default pitzDailyMapped killing fluctuations
Eman. is on a distinguished road
HI,
I was going through the pitzDailyMapped folder and it is supposed to create a turbulent inflow condition by mapping the velocity at a plane located in the downsteam of the flow back to the inlet plane. I noticed it uses averaging of velocity to maintain the volumetric flux. However, the average vector is (10,0,0), which means it kills the eddies and therefore the fluctuations over time by mapping the Uy and Uz to zero. Isn't it the whole idea of LES to take the fluctuations larger than the filter width into account? I assume the inlet profile would approach that of a laminar flow after enough time steps and if I'm right the whole simulation case of "pitzDailyMapped" makes no sense. Am I missing something here? any idea?
Many thanks in advance.
Eman. is offline   Reply With Quote
Old   January 2, 2017, 08:06
Juho Peltola
juho is on a distinguished road
Here you can see how the setAverage works:
https://github.com/OpenFOAM/OpenFOAM...tchFieldBase.C
   if (setAverage_)
        Type averagePsi =
            gSum(patchField_.patch().magSf()*newValues)
           /gSum(patchField_.patch().magSf());
        if (mag(averagePsi)/mag(average_) > 0.5)
            newValues *= mag(average_)/mag(averagePsi);
        else
            newValues += (average_ - averagePsi);
Eman. likes this.
juho is offline   Reply With Quote
Old   January 2, 2017, 17:32
   if (setAverage_)
        Type averagePsi =
        else
Thanks a lot for the reply. So, it rescales the velocity to maintain the flow rate. However, I tried to use mapped boundary condition on different geometries (2D and 3D) and everytime turbulence decays and I end up with a laminar velocity profile.
Also here on page 15 you can see:
"Care must be taken not to make the control algorithms too efficient; if the velocity control is too good then it can have the effect of completely destroying fluctuations in the velocity, thus unintentionally relaminarising the flow."
Old   January 3, 2017, 11:44
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
the way that channelFoam use to work for this type of application was to use a cyclic BC with a pressure gradient to drive the flow in a user-specified direction. Without the pressure gradient -> the flow decays. There is an fvoption in openFOAM-plus for pressure gradient source term to replicate that of channelFoam used like:
    airDeflection
        type            directionalPressureGradientExplicitSource;
        active          true;
        directionalPressureGradientExplicitSourceCoeffs
            selectionMode   cellZone;
            cellZone        cZone;
            fieldNames  (U);            // Name of the field
            flowDir     (1 1 0);        // Desired flow direction
            faceZone    f0Zone;         // Face zone upstream cell zone
            relaxationFactor    0.3;    // Relaxation factor for flow
                                        // deflection (default 0.3)
            //Pressure drop model [Pa]
            model       volumetricFlowRateTable;//constant;//DarcyForchheimer;
            //DarcyForchheimer model
            // deltaP = (D*mu + 0.5*rho*magUn)*magUn*length_
            D           5e7;
            I           0;
            length      1e-3;
            //constant model
            pressureDrop    40;
            //volumetricFlowRateTable model
            outOfBounds     clamp;
            fileName        "volFlowRateTable";
chegdan is offline   Reply With Quote
Old   May 4, 2023, 16:01
CFD_Lovers
sinatahmooresi is on a distinguished road
Hello Eman,
Did you solve this issue? The problem in which you get laminar flow when applying the mapped velocity boundary condition. I am trying to simulate a pipe flow using this method and all I get is a averaged-looked profile instead of a fluctuating one.
Thank you,
Sina
sinatahmooresi is offline   Reply With Quote
large eddy simulation, mapped boundary condition, mapped condition, pitzdaily
How does CFX initialize velocity fluctuations in LES? dtmith CFX 3 June 4, 2017 04:09
Inlet fluctuations issue in LES Ivan Main CFD Forum 0 October 15, 2012 13:57
numerical prediction of Pressure fluctuations in hydraulic jump masoud197 CFX 1 January 22, 2012 18:58
Obtaining RMS of turbulent velocity fluctuations rks171 Main CFD Forum 0 January 19, 2012 09:45
about turbulence random fluctuations ben Main CFD Forum 2 December 23, 2004 21:23
