if function and turbulence->k()
Like Tree4Likes
  • 1 Post By floquation
Old   December 21, 2016, 19:38
Default if function and turbulence->k()
Zack is on a distinguished road
Hi All
I am trying to use if function for the non-zero value of turbulence->k():
if (turbulence->k() != 0.0)
do ....
else
do ...
What is the proper way of writing that? I tried different form, such as:
if (turbulence->k() Foam::operator!= 0.0)
which after compiling it gave me the below error:
myCreateFields.H:7:21: error: expected ) before Foam
myCreateFields.H:7:41: error: could not convert Foam::turbulenceModel::k() from Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > to bool
Thanks.
Zack
Zack is offline   Reply With Quote
Old   December 22, 2016, 04:27
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Please always write code between [CODE]-tags. Without it, it is barely readable.
The function "turbulence->k()" is defined as:
        //- Return the turbulence kinetic energy
        virtual tmp<volScalarField> k() const = 0;
In other words, it returns a volScalarField, which is a field. It is not a single value, hence you cannot compare it with a single value (!=0.0) like you are trying.
With that being said, your question cannot be answered, unless you explain to us what exactly it is that you want:
Should this if-function be evaluated for each cell of the domain? Do you want to check if k=0 somewhere? Should k=0 everywhere?
Zack likes this.
floquation is offline   Reply With Quote
Old   December 22, 2016, 09:53
Thank you Kevin for your reply and help.
I need to check the k value at each single cell of the domain.
Old   December 22, 2016, 10:02
floquation's Avatar
Kevin van As
Very well. I haven't done this before, but I guess the following should work:
            for (int celli = 0; celli < mesh.nCells(); celli++){
                if (turbulence->k()[celli] != 0)
                    // Stuff.
                else
                    // Other stuff.
            forAll(mesh.cells(), celli){
                    // Stuff.
                else
                    // Other stuff.
Old   December 22, 2016, 11:02
Kevin
For both cases I am getting the same error:
In file included from FSCModifiedbEqn.H:203:0,
                 from FSCModifiedFoam.C:108:
newStModel.H:4:20: error: no match for operator[] (operand types are Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > and int)
Old   December 22, 2016, 12:29
floquation's Avatar
Kevin van As
Hm. I think that is because the k()-function returns a tmp<volScalarField>, which is a "smart-pointer". We must first dereference it to obtain the volScalarField, of which we would like to take the celli'th element. (Again, I haven't done this before, I'm learning these things right now.)
Try the following (let me know whether they work):
turbulence->k()()[celli] // get const reference
turbulence->k().ref()[celli] // get non-const reference
See also:
${FOAM_SRC}/OpenFOAM/memory/tmp/tmp.H
Zack likes this.
Old   December 24, 2016, 18:45
Kevin
Using both of the suggestions, it seems they both can solve the issue with the if-statement. But It seems this causes another issue!
Imagine that in my bEqn.H file I need to solve:
 fvm::laplacian( rho*Dtt, b)
and I have Dtt which is defined as volScalarField in "myCreateField.H" file.
Before adding the if-statement, the bEqn can recognize the Dtt and I can compile it with no error! But now, after adding if-statement, using both suggestions, I am getting below error:
 Dtt was not declared in this scope
Old   January 4, 2017, 17:49
floquation's Avatar
Kevin van As
Sorry for being slow -- holidays.
Based on your post, I'm not sure what could possibly go wrong. If a variable is defined outside the if-condition, it is automatically defined inside the if-condition.
Could you post the code that you tried?
Old   January 6, 2017, 17:09
myCreateFields.H
Info<<"Reading myCreateFields.H File"<<endl;
scalar Cmu=0.09;
volScalarField up = uPrimeCoef*sqrt((2./3.)*turbulence->k());
forAll(mesh.cells(), cellI)
if (turbulence->k()()[cellI] != scalar(0.0)){
	#include "Fields1.H"
else{
	#include "Fields2.H"
Info<< "\nReading field Tu\n" << endl;
volScalarField Tu
	IOobject
		"Tu",
		runTime.timeName(),
		mesh,
		IOobject::MUST_READ,
		IOobject::AUTO_WRITE
	mesh
Info<< "\nReading field activT\n" << endl;
volScalarField activT
	IOobject
		"activT",
		runTime.timeName(),
		mesh,
	mesh
//calculating T_Tild
Info<< "Calculating T_Tild\n" << endl;
volScalarField T_Tild
	IOobject
		"T_Tild",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
	Tu*(b+((thermo.rhou()/rho)*(1-b)))
Info<< "\nReading field alphab\n" << endl;
volScalarField alphab
	IOobject
		"alphab",
		runTime.timeName(),
		mesh,
	mesh
Info<< "\nReading field tr\n" << endl;
volScalarField tr
	IOobject
		"tr",
		runTime.timeName(),
		mesh,
	mesh
Fields1.H
volScalarField L = Foam::pow(Cmu,scalar(0.75))*pow(turbulence->k(),1.5)/turbulence->epsilon();
volScalarField tauTurb = L/up;
volScalarField tauChem = thermo.alpha()/(rho*pow(unstrainedLaminarFlameSpeed()(),2));
volScalarField Da = tauTurb/tauChem ;
volScalarField tO=0.1*L/up;
//Required to calculate Dt and Dtt
scalar PrandtlTurb=0.7;
//calculating St
Info<< "Calculating S_turb\n" << endl;
volScalarField S_turb
	IOobject
		"S_turb",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
	XiShapeCoef*up*pow(Da,0.25)
//calculating Dt
Info<< "Calculating  Dt\n" << endl;
volScalarField Dt
	IOobject
		"Dt",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
	(Cmu/PrandtlTurb)*(pow(turbulence->k(),2.)/turbulence->epsilon())
volScalarField tauTurbPrime = Dt/(Foam::pow(up,2.0));
//calculating S_turbTimeDependent
Info<< "Calculating S_turbTimeDependent \n" << endl;
volScalarField S_turbTimeDependent
	IOobject
		"S_turbTimeDependent",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
	S_turb*Foam::sqrt(mag(1.+tauTurbPrime/(runTime-tO)*(Foam::exp(-1.*(runTime-tO)/tauTurbPrime)-1.)))
//calculating Dtt
Info<< "Calculating Dtt\n" << endl;
volScalarField Dtt
	IOobject
		"Dtt",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
	Dt * (1-Foam::exp(-1.*(runTime-tO)/tauTurbPrime))
	//Dt * (1-exp((-(runTime+tO))/tauTurbPrime))
Fields2.H
volScalarField L = Foam::pow(Cmu,scalar(0.75))*pow(turbulence->k(),1.5)*turbulence->epsilon();
volScalarField tauTurb = L*up;
volScalarField tO = 0.1*L*up;
//calculating St
	IOobject
		"S_turb",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
//calculating Dt
volScalarField Dt
	IOobject
		"Dt",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
	(Cmu/PrandtlTurb)*(pow(turbulence->k(),2.0)*turbulence->epsilon())
volScalarField tauTurbPrime = Dt*(pow(up,2.0));
	IOobject
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
	S_turb*up
//calculating Dtt
volScalarField Dtt
	IOobject
		"Dtt",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
	Dt *up
bEqn.H
// Create b equation
    fvScalarMatrix bEqn
        fvm::ddt(rho, b)
       + mvConvection->fvmDiv(phi, b)
       + fvm::div(phiSt, b, "div(phiSt,b)")
       - fvm::Sp(fvc::div(phiSt), b)
       - fvm::laplacian( rho*Dtt, b)
       + fvm::Sp(rho*Foam::exp(-activT/T_Tild)/(tr*(1+Dtt/alphab)), b)
	 //-------End--------//
Old   January 9, 2017, 04:38
floquation's Avatar
Kevin van As
Your code may be reduced to the following statement:
if ( condition )
    int a = 0;
else{
    int a  = 1;
a = a + 1; // error, a not declared
Since you define your variable (here, a) inside the if-condition, it is not known outside the if-condition.
A correct statement would be:
int a;
if ( condition )
    a = 0;
else{
    a  = 1;
a = a + 1; // OK!
In your case, you'd want three include files:
#include "Fields_init.H"
    #include "Fields_set1.H"
else{
    #include "Fields_set2.H"
Fields_init.H declares the fields that must be known outside the if-condition.
Fields_set#.H initialise those fields by assigning values to them.
(#include "Fields_init.H" should, of course, be outside your for-loop as well, if those variables should be known outside of the scope of your for-loop.)
Zack likes this.
Old   January 22, 2017, 20:16
Hi Kevin
Sorry for late reply and thanks for your help. It worked fine...
One ore question for you. If I need to set the value of any volume scalar field to zero and I consider the unit for that as well, how can I do that?
Lets say that I have VolScalarField B which has (m/s) as its unit and I need to define its value at special condition as zero:
volScalarField B1 = scalar (0.0);  //unit m/s
Old   January 23, 2017, 05:51
floquation's Avatar
Kevin van As
    // Just to get myself a volScalarField, you won't need this line:
    volScalarField alpha = this->lookupObject<volScalarField>("alpha.water");
    // Overwrite the entire volScalarField with a constant value of specified dimension:
    alpha=dimensioned<scalar>("name",dimensionSet(0,1,-1,0,0,0,0),scalar(0.0));
    // This will result in a run-time error, because the dimensions of alpha are not m/s, meaning it works.
I urge you to install an IDE. An IDE will allow you to fairly quickly figure out how to do such things by simply looking at the constructors and "operator=" of the entity you wish to create (here: volScalarField). Besides, it has auto-completion and find-declaration functionality to quickly find the relevant pieces of source code.
Personally, I use Eclipse.
Zack likes this.
in k-epsilon wall function approach high Re turbulence models: question of velocity romant OpenFOAM Programming & Development 6 May 26, 2016 10:14
issue compiling new turbulence model perplexed user OpenFOAM Programming & Development 1 January 13, 2012 04:40
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
3-D turbulence model with wall function Henry Main CFD Forum 7 May 19, 2006 11:40
