Easiest way to plot pointDisplacement
Like Tree2Likes
  • 2 Post By havref
Old   November 22, 2016, 12:04
Default Easiest way to plot pointDisplacement
Håvard B. Refvik
havref is on a distinguished road
Hi!
I want to do a few heave decay test of some objects in 2D and 3D. However, I am not sure how to properly plot the displacement over time for the objects. If I for example look at the FloatingObject tutorial, what would be the best approach to plot its displacement over time? I'm mainly concerned with the vertical direction first, but for the 3D case I would like to plot for all three directions, plus pitch, heave and yaw.
Is paraView a good option, or will I have to write a script to read the sixDof output directly? If so, does anyone have any scripts available that could help me on my way?
Myiced and Zmm like this.
havref is offline   Reply With Quote
Old   November 25, 2016, 08:37
Saideep
Saideep is on a distinguished road
I use interFoam solver and if I have a bubble or a slug flowing within a channel, I use center of mass as a variable to describe the displacement.
I never used it for more complicated cases such as 2 slugs in a channel but i guess even that could be possible if some sort indexing can be given for individual entities.
Saideep is offline   Reply With Quote
decay test, heave, pitch, sixdof, sixdofrigidbodymotion
Contribute a forceCoeff plot and merge utility lakeat OpenFOAM Running, Solving & CFD 5 October 5, 2018 23:48
How to plot Cp Vs X/c abhiprayj Main CFD Forum 1 March 28, 2017 03:58
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 16:40
Plotting two plot values in One plot bharatesh Tecplot 2 May 29, 2015 02:10
graph plot anindya Main CFD Forum 2 September 17, 2003 13:00
