FLOW3D scary tactic about VOF
Like Tree4Likes
  • 1 Post By JonW
  • 2 Post By nsf
  • 1 Post By JonW
Old   November 11, 2016, 10:20
Default FLOW3D scary tactic about VOF
Jon Elvar Wallevik
JonW will become famous soon enough
Hi foamers
I saw just now on the following link...
https://www.flow3d.com/home/resource...ats-in-a-name/
...that most other CFD software were only using a “Pseudo-VOF methods” and not the real VOF (or truVOF). Cleary they do not grasp the different family trees of VOF. But still, the simulation case shown in this page is interesting. So my question is, has anybody done this simulation in OpenFOAM? If so, could you share the result and case? (I could do this, but I am just swamped in workload for now ).
I think this is a big deal for FLOW3D and I have seen other use this as a justification for using it (phd works).
Cheers
Jon
thunde47 likes this.
JonW is offline   Reply With Quote
Old   November 14, 2016, 17:23
nsf
Nicolas Edh
nsf is on a distinguished road
Hi Jon,
I'm no VoF expert but I did setup a similar case. I had to guess at the size, I guessed at a domain length of 400 mm. Which gives a Re number somewhere near the transition region. Perhaps the domain size should be a factor of 10 smaller.
Depending on the setting you can observe the "incorrect shape". For instance try the case I provided and activate "no-slip" on walls and turn on turbulence.
In the attached picture you can indeed see that the interface is not sharp but there is that expected "flaw". However I wouldn't deem it very disturbed.
Maybe someone else can provide some more interesting thoughts.
The case is meshed with cfMesh. I couldn't attach the case with the mesh since it's to big but you can download it including the mesh here.
And the case files can be downloaded from here:
https://www.dropbox.com/sh/2ec65aqdi...6T1hO5J_a?dl=0
Best Regards
Nicolas
PS. due to the bug at cfd-online I couln't post this sooner.
nsf is offline   Reply With Quote
Old   November 15, 2016, 16:39
Jon Elvar Wallevik
Thank you for this Nicolas
This is not bad at all . That is, at least the outcome is not as bad as in the worse case shown with FLOW-3D.
The cfMesh interest me (i.e. the GPL version). Do you know of any manual of this meshing tool as a pdf file?
Cheers
J.
Old   November 17, 2016, 17:29
nsf
Nicolas Edh
Cheers
J.
Hi, funny thing. Yesterday I was at the Gothenburg OpenFoam meeting and there was a presentation on isoAdvector, a new scheme which deals with this issue. Have a look here
http://www.cfd-online.com/Forums/ope...culations.html
Yes cfMesh is a really great tool! There's a comprehensive manual included with the source code. It real easy to compile and getting started. Do try it.
Best Regards
Nicolas
JonW and franjo_j like this.
Old   March 21, 2017, 14:25
Jon Elvar Wallevik
Relative to the first post above “different family trees of VOF”…
I just published a paper in which a modified version of the interFoam is used, available for download at:
http://dx.doi.org/10.1016/j.cemconres.2017.02.007
In section 2.2 I talk about the two VOF families, namely the direct methods and the reconstruction methods. So if you need a short intro or references, then here you are.
Unfortunately, I didn’t know about the isoAdvector at the time of writing, so it’s not referred to (will be included in the next paper), but as far as I understand, that method belongs to the reconstruction method.
Cheers
Jon
nsf likes this.
Old   August 5, 2020, 11:06
thunde47
thunde47 is on a distinguished road
So what was the conclusion on this? Any further developments/works comparing the Real VOF and Pseudo VOF methods?
thunde47 is offline   Reply With Quote
problem about VOF and species couple Cloud FLUENT 0 June 15, 2012 02:23
ATTENTION!! Validty of Fluent's VOF?? ozgur Main CFD Forum 3 February 18, 2004 19:19
ATTENTION!! Validty of Fluent's VOF?? ozgur FLUENT 1 February 18, 2004 12:59
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 08:39
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 09:25
