help! VOF method in OpenFOAM
Like Tree1Likes
  • 1 Post By vigneshTG
Old   October 19, 2016, 06:29
Smile help! VOF method in OpenFOAM
LXJ
liuxiaojian2015 is on a distinguished road
OpenFOAM is excellent on the simulating single phase flows. However, the VOF method in OpenFOAM is doubted by lacking one important step: ‘free-surface reconstruction.’ The VOF method is ideal for studying the wave dynamics. It includes two major steps: 1. Re-distribute fluid mass based on the VOF equation. 2. Reconstruct the free-surface for accurately estimating the volume flux on each cell face. The first step was included in the OpenFOAM. However, the second one is not. It results on the smoke-like breaking waves in OpenFOAM. Anyone konw how to slove it? Please shall your address.
liuxiaojian2015 is offline   Reply With Quote
Old   October 19, 2016, 17:14
Vignesh
vigneshTG is on a distinguished road
Hi Liu,
Interfoam solver in Openfoam is a Pseudo VOF method which is different from Geometrical VOF methods like PLIC. In interfoam, solving the governing equation for vof (which includes an additional interface compression term) is another alternative to the geometrical method which includes reconstruction and advection.
Try refining the mesh, changing the Courant number may be it helps a little
Linmunn likes this.
Thanks and Regards
Vignesh
vigneshTG is offline   Reply With Quote
Old   October 20, 2016, 01:40
LXJ
Originally Posted by vigneshTG View Post
Hi Liu,
Hi Vignesh,
Thank you very much for your reply. Meanwhile, thank you for your help and valuable advises. Though try refining the mesh, the phenomenon of smoke-like breaking waves still exist when amplify the free surface. Because the reconstruction of free-surface was not included in the OpenFOAM by using the MULES scheme on the simulating two phase flows. Do you know other method included in the OpenFOAM can slove the phenomenon of smoke-like breaking waves.
Enjoy,
Xiaojian Liu
Old   October 20, 2016, 04:24
Vignesh
Originally Posted by liuxiaojian2015 View Post
Hi Vignesh,
Enjoy,
Xiaojian Liu
Hi Liu,
Try to explain your problem in detail (showing some snapshots of interface and your mesh size, solver settings) there might be some one who could help you.
check this thread
Thanks and Regards
Vignesh
Old   March 13, 2018, 01:08
Smile
LXJ
This is the result of smoke-like breaking waves! Anyone is welcomed to discuss it. Thanks.
Last edited by liuxiaojian2015; March 13, 2018 at 01:15. Reason: A error operation so that the picture can not be loaded
Old   November 10, 2022, 06:50
Michael Sukham
2538sukham is on a distinguished road
Even i get the unphysical interface when using interDyMFoam on circular cylinder with piston moving resulting in topochangnig simulations. Have you got rid of it? Putting max Co to 0.1 resuces but it doesnt eliminate the problem. Still open to share the solution.
2538sukham is offline   Reply With Quote
Old   November 18, 2022, 05:50
Default interIsoFoam instead of interFoam?
Jon Elvar Wallevik
JonW will become famous soon enough
Have you considered interIsoFoam. It is available in the ".com" version of OF, i.e. openfoam.com. I believe it has some kind of reconstruction phase.
P.s. For the interested, in the paper below, the two major VOF families are summarized in a short and clear manner, namely the direct methods and the reconstruction methods, see...
Analysis of shear rate inside a concrete truck mixer, Cement and Concrete Research, Vol. 95, 2017, pp 9-17.
https://www.sciencedirect.com/scienc...08884616310961
hope this helps
J.
JonW is offline   Reply With Quote
Old   November 28, 2022, 00:57
Michael Sukham
With layer addition/removal for topologically changing meshes, I guess I have to make changes to the base iso advector interface capturing scheme. Hope it comes out for foam extend.
Old   February 1, 2023, 05:46
Michael Sukham
The wave has oscillations. Simply refining the mesh actually makes the computation longer without much improvement in the results. It occurs specially when the wave run up becomes higher. 1 second and 1.42 seconds pictures are attached for reference of the problem.
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
Contrl volume /finite element method implemented by OpenFoam uuivw OpenFOAM Programming & Development 0 May 24, 2014 05:00
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM keepfit OpenFOAM 4 January 31, 2014 15:32
[ImmersedBoundary] who has the paper about immersed boundary method in openfoam blueshit OpenFOAM Community Contributions 1 November 18, 2013 08:16
