[Tutorials] New Dakota - OpenFOAM Coupling Tutorial
Like Tree6Likes
  • 6 Post By Tobi
Old   October 9, 2016, 18:19
Default New Dakota - OpenFOAM Coupling Tutorial
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Dear all,
today I published a new Dakota - OpenFOAM coupling tutorial. The tutorial itself is a mixing case of a hot and cold fluid stream with two obstacles. There are three design variables and two respond functions that are evaluated with a Latin Hypercube Sampling (LHS) method build-in in Dakota. The tutorial focus on the coupling and not on the capabilities of Dakota and how to use it for optimization of the respond functions. The user can simple change the Dakotas method and use the respond function for doing a optimization (but it is not the aim of the tutorial).
Summing up
The three design (geometric) variables are:
  1. Angle of obstacle 1
  2. Angle of obstacle 2
  3. Length (area) of cold inlet
The respond functions that are evaluated are:
  1. The flux weighted mean temperature at the outlet patch
  2. The homogeneous temperature distribution at the outlet patch
With the LHS method we evaluate 80 different kinds of combinations. One result can be checked out in the Holzmann CFD :: DAKOTA® - OpenFOAM® Coupling video.
The case can be found on my website » OpenFOAM » Dakota Coupling
Thanks to Harald Unger for the case idea; I highly appreciate that. I hope that this tutorial will help you to understand the coupling and can apply it to your problems.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
Coupling of OpenFOAM solvers Annier OpenFOAM Running, Solving & CFD 1 January 5, 2015 11:50
Coupling OpenFOAM with Abaqus skuznet OpenFOAM Programming & Development 4 January 21, 2014 11:56
