September 14, 2016, 03:56 |
Blood flow in artery including FSI
Viraj Belekar
Rep Power: 10 |
Greetings,
I am trying to simulate blood flow in artery. I want to implement FSI(Fluid Structure Interaction) for this simulation as well. I also want to consider the Non-Newtonian nature of blood. Can anyone suggest me the best solver I can use in OpenFOAM or foem-extend? Thanks |
September 14, 2016, 05:32 |
anas
Rep Power: 11 |
Did you check the icoFsiFoam solver in foam-extend-3.1.
All the best Ahmad |
September 14, 2016, 06:00 |
#3 | |
Viraj Belekar
Rep Power: 10 |
Hi Ahmad, Yes, I tried using it. I also tried using icoFsiElasticNonLinULSolidFoam solver. I just wanted to confirm which one would be best. I tried using icoFsiFoam but the simulation fails after one iteration. I will get back here once I figure out the issue Thanks Last edited by viraj20feb; September 14, 2016 at 06:03. Reason: missing info |
March 7, 2017, 15:01 |
Lucas Ribeiro
Rep Power: 10 |
Have you succeed? Regards |
need help with fsi of blood flow through artery | Shilpa | FLUENT | 3 | January 19, 2017 09:14 |
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) | Julian K. | CFX | 2 | September 15, 2011 16:30 |
Blood flow analysis | kmgraju | FLUENT | 0 | May 20, 2011 03:19 |
Simulation of air flow inside valve - FSI? Help! | farianka | Main CFD Forum | 0 | April 17, 2011 17:30 |
blood flow simulation start-up hints please | olumide olododo | Main CFD Forum | 4 | May 31, 2004 12:33 |
