How to build complex geometry in openfoam?
Like Tree1Likes
  • 1 Post By Tobi
Old   September 11, 2016, 13:06
Smile How to build complex geometry in openfoam?
JIN WEIGUO
Mark JIN is on a distinguished road
Hi friends,
I was an ansys user and now is atarting with openfoam for my cfd analysis. After understanding some openfoam basics, I was trying to convert fluent mesh into openfoam format, but some errors came, not sure what's the problem, maybe complexity or naming..
Just want to understand what could be an effective way to build complex geometry (such as an urban site with building windows open) and have openfoam to read it, any thrid party software available?
Thanks a lot!
Mark
Mark JIN is offline   Reply With Quote
Old   September 12, 2016, 06:02
g.freeman is on a distinguished road
Originally Posted by Mark JIN View Post
Hi friends,
Thanks a lot!
Mark
Can you report the error? I often make my mesh in ICEM and then convert it in OF without any problem.
This could also be useful for you: http://cfd.direct/openfoam/user-guid...#x27-1940005.5
g.freeman is offline   Reply With Quote
Old   September 15, 2016, 06:01
JIN WEIGUO
Thanks for ur help, here is my error.
I built solid blocks through design modeller and created enclosure. Then I suppressed the solid bodies (with only enclosure left) and gave 'inlet' 'outlet' naming only.
markjin@markjin-VirtualBox:~/OpenFOAM/markjin-4.0/run/Case3$ fluentMeshToFoam Case3.msh
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.0-665f1db4c1f1
Exec : fluentMeshToFoam Case3.msh
Date : Sep 15 2016
Time : 18:51:23
Host : "markjin-VirtualBox"
PID : 4063
Case : /home/markjin/OpenFOAM/markjin-4.0/run/Case3
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Embedded blocks in comment or unknown: (
Found end of section in unknown
Dimension of grid: 3
Number of points: 10036
number of faces: 26210
Number of cells: 8129
Reading points
Reading points
Reading mixed faces
Reading mixed faces
Reading mixed faces
Reading mixed faces
Other readCellGroupData: 2 1 1fc1 1 0
Reading mixed cells
Read zone1:1 name:interior-solid patchTypeID:interior
Reading zone data
Read zone1:2 name:solid patchTypeID:fluid
Reading zone data
Read zone1:5 name:inlet patchTypeID:velocity-inlet
Reading zone data
Read zone1:6 name outlet patchTypeID pressure-outlet
Reading zone data
Read zone1:7 name:wall-solid patchTypeID:wall
Reading zone data
FINISHED LEXING
#0 Foam::error: printStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? at ??:?
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#5 ? at ??:?
Segmentation fault (core dumped)
Old   September 15, 2016, 07:31
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
I can not help you with the ICEM import (I did it only for simple 2D cases during my study time) but for 6 years now, I am using snappyHexMesh for everything. See the wiki site, the openfoam tutorials or check out my website. The next two tutorials that I will publish are:
  • Sphere, Diffusor combustion chamber
  • Jet-Engine Turbine
Dipsomaniac likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   September 18, 2016, 09:38
JIN WEIGUO
Originally Posted by Tobi View Post
Hi Tobi, thanks for your help. May I describe my case here? It would be great if you get time to give any sugguestion!
Simply, I want to use openfoam for natural ventilation analysis. I will need to build a cluster of buildings and an enclosure around them where wind blows within the enclosure, that's what I did using 'Ansys design modeller and meshing' before. But it seems it is not workable when I do 'fluentMeshToFoam' trying to convert boths buildings and enclousre in the meantime.
I saw some talks about snappyHexMesh and Salome, is it true that I need to export building geometry and enclosure geometry seperately into STL format that openfoam can read? Do you have any sugguestion?
Thank you so much!!!
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
[ICEM] Complex Geometry for Hex Mesh smoerebroet ANSYS Meshing & Geometry 0 January 9, 2015 16:21
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
