Moving Mesh
Like Tree1Likes
  • 1 Post By Saha S
Old   May 26, 2016, 13:45
Default Moving Mesh
Saha S is on a distinguished road
I like to know if anyone is familiar with handling moving mesh in OpenFoam. I like to do a evaporation modeling, I want to track the liquid-air interface as it comes down due to evaporation. Thank you.
Kummi likes this.
Saha S is offline   Reply With Quote
Old   May 30, 2016, 04:53
Default Heat transfer and rotating mesh
ChriK is on a distinguished road
Hello everyone,
I'm new in OpenFoam and I have a basic question: Is it possible to analyze with OpenFoam the average heat transfer coefficient of rotating geometries in a turbulent flow domain depending on the velocity of the cooling flow, the rotation velocity of the geometry, the temperatures of cooling flow and the geometry,… I ask this question because according to the OpenFoam C++ Documentation (http://openfoam.com/documentation/cp...ml/a11233.html) you can choose moving mesh solvers, but than in this category there is no heat transfer solver included? I am at the very beginning with CFD so I’m sorry if this is a stupid question…
Thank you very much!
ChriK is offline   Reply With Quote
Old   May 30, 2016, 09:29
Brian Willis
Dipsomaniac is on a distinguished road
Hi Saha
In a solver like interFoam (with phase change... interPhaseChangeFoam) the interface isn't directly captured or tracked. You would have to post process (maybe using Paraview) the transport of the phase fraction (alpha) to determine where the interface is (where alpha s 0.5).
Regards,
Brian
Dipsomaniac is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Trying to set up Moving Mesh Problem dreamchaser CFX 5 December 15, 2014 01:07
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
