Lewis number of chemical species
Like Tree1Likes
  • 1 Post By kalle
Old   April 18, 2016, 16:02
Default Lewis number of chemical species
Sheikh Ahmed
sahmed is on a distinguished road
Hi
I am simulating reacting flow in a flow reactor with complete chemistry. For that, I need to provide a complete the Lewis numbers of all the species that I have in chemical mechanism.
Could anyone tell me a reliable source which I can use for Lewis number of difference chemical species, or any other suggestion on that.
sahmed is offline   Reply With Quote
Old   April 19, 2016, 02:53
Karl-Johan Nogenmyr
kalle is on a distinguished road
Have a look here:
http://www3.nd.edu/~powers/ame.60636/transport.pdf
atulkjoy likes this.
kalle is offline   Reply With Quote
Old   April 19, 2016, 11:33
Sheikh Ahmed
Thanks Kalle for your reply. I looked into this doc before. I need a database with either Lewis number of common species or the mass and thermal diffusion coefficients from which I can calculate the Le. This doc does not have those.
Please let me know if you know any other sources.
Old   April 19, 2016, 16:34
Karl-Johan Nogenmyr
Sure, there is all you need there... in chapter 6 you have species data that you plug in to the equations.
Mixtue averaged thermal conductivity - eq 50
Binary diffusion rate for specie: eq 3.. maybe your system contains a lot of N2, then you can let your specie diffuse into N2?
lewis number, reacting flow
timeVaryingMappedFixedValue: large data mapping on complex inlet boundaries vkrastev OpenFOAM Pre-Processing 7 June 2, 2016 16:50
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
chemical species mass fraction Green_Horn STAR-CD 0 February 27, 2012 15:57
