2 Phase Flow, Gas Jet into Water Simulation Method
Like Tree1Likes
  • 1 Post By im_lenny
Old   August 21, 2015, 17:53
Default 2 Phase Flow, Gas Jet into Water Simulation Method
Leonard Cassady
im_lenny is on a distinguished road
I am modeling the flow of a high speed gas jet (Mach 0.5) into a large volume of water using OpenFoam. I would like to model the turbulent interface between the phases, so I am using a full 3D simulation with LES. I am primarily concerned with the portion of the jet near the exit, where the gas flow is slowing down and expanding as it transfers momentum with the water.
Should I use a Volume of Fluid method (compressibleMultiphaseInterFoam) or a Euler-Euler method (twoPhaseEulerFoam) for the solver?
The Euler-Euler method solves conservation equations for each phase separately and assumes that one phase is dispersed in the other. (Although there is a mulitphaseEulerFoam, so which phase is dispersed in the other probably doesn't matter.) The concern with the Euler-Euler method is that the gas would artificially disperse into the liquid too quickly.
The VoF method only solves one set of momentum and pressure equations for the system. The concern is that the momentum transfer between phases won't be strong enough and the jet will take a longer distance than it should to slow down.
Again, which solver should I use for a high-speed, high-flow-rate gas jet into water?
Thanks.
im_lenny is offline   Reply With Quote
Old   May 3, 2017, 06:35
Kumar
kishpishar is on a distinguished road
Have you been able to find out the right solver for your application?
I am in a similar situation as I need to inject a high-velocity gas jet (about 120 m/s) through a nozzle horizontally into a large pool of water. I need to find out the gas jet penetration and the jet trajectory as well as the induced circulation of water. I didn't have much luck with twoPhaseEulerFoam. Could you please give me some advise?
Thank you
Kumar
kishpishar is offline   Reply With Quote
Old   May 3, 2017, 14:20
Leonard Cassady
CompressibleInterFoam does a good job with a submerged gas jet. I haven't been able to get twoPhaseEulerFoam to work with medium or high speed flows.
Lenny
kishpishar likes this.
Old   May 4, 2017, 04:20
Kumar
Hi Leonard - it seems to me that the highly coupled nature of twoPhaseEulerFoam with compressibility and energy effects is the source of divergence. I'll try with multiphaseEulerFoam as well as with compressibleInterFoam. Thanks
-Kumar
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
gas jet simulation Hassen FLUENT 0 April 25, 2013 15:52
Jet in Supersonic Crossflow, controlling mass flow rate ChrisA OpenFOAM Running, Solving & CFD 3 November 13, 2012 19:20
Solar Panel Water heating using solidwork Flow Simulation axtray FloEFD, FloWorks & FloTHERM 2 September 21, 2011 16:47
Gas solid two phase flow Liwau CFX 4 March 19, 2004 12:08
