July 21, 2015, 13:52 |
circuit board cooling ?
OSM
Rep Power: 11 |
Hi , pleas i need help , i have a project of simulation a Conjugate Heat Transfer i mean cooling tow hot cpus (hot processor) attached to a motherboard with one Source of cold air (fan) ,so
what is the solver for my problem : circuit board cooling or chtMultiRegionSimpleFoam/heatExchanger ?? i start to create my geometry using Salome . pleas i need your help . Last edited by liloM; July 21, 2015 at 16:38. |
July 21, 2015, 13:58 |
OSM
Rep Power: 11 |
July 21, 2015, 15:26 |
OSM
Rep Power: 11 |
somebody can help me , please?
July 22, 2015, 04:44 |
amine
Rep Power: 12 |
Hi
You can use chtMultiRegionSimpleFoam or chtMultiRegionFoam. Make your simulation with OF 2.4.0 because there is a bug in OF 2.3.0 when you try to put a volumetric heat source. If you have a complex geometry I think Salome is not a good solution. You can use FreeCAD or DesignSpark Mechanical 2.0 (free software under windows). Good luck |
July 22, 2015, 06:31 |
#5 | |
OSM
Rep Power: 11 |
My geometry contain only a motherboard with 2 boxes represent a 2 CPUs and one cylinder as a obstacle , for the solver chtMultiRegionSimpleFoam there is heatExchanger and multiRegionHeaterRadiation wich one i should use , and what is the deference between chtMultiRegionFoam and chtMultiRegionSimpleFoam for my case . If i use FreeCAD or DesignSpark ! wich converter i would use to OpenFoam ( Like ideasUnvToFoam for the .unv format ) . Thank You for your help . |
July 22, 2015, 09:12 |
amine
Rep Power: 12 |
Hi
chtMultiRegionSimpleFoam solver contain two exemple: multiRegionHeaterRadiation ==> simulation of convection, conduction and radiation heatExchanger ==> simulation of convection and conduction chtMultiRegionFoam: Combination of heatConductionFoam and buoyantFoam for conjugate heat transfer between a solid region and fluid region chtMultiRegionSimpleFoam: Steady-state version of chtMultiRegionFoam You can use FreeCAD or DesignSpark and export you geometry in stl format to be able to mesh him with snappyHexMesh If you want to mesh you geometry under SALOME you can use this python script salomeToOpenfoam (ideasUnvToFoam is not necessary) |
July 22, 2015, 12:21 |
#7 | |
OSM
Rep Power: 11 |
Thank You Sooo Match
and FreeCad as design tool , whay ? (ideasUnvToFoam is not necessary) it work !. Last edited by liloM; July 22, 2015 at 14:14. |
July 23, 2015, 06:45 |
amine
Rep Power: 12 |
Hi
Do you have understand that heatExchanger is an exemple and chtMultiRegionSimpleFoam is solver? The choice of CAD software is depend on yout experience. strategy CAD (FreeCAD or DesignSpark) ==> export stl file ==> Mesh (snappyHexMesh) ==> OpenFoam CAD (FreeCAD or DesignSpark) ==> export (stl, step,...) file ==> Mesh (SALOME) ==> export .unv (ideasUnvToFoam is necessary) ==> OpenFoam CAD (SALOME) ==> Mesh (SALOME) ==> export .unv (ideasUnvToFoam is necessary) ==> OpenFoam CAD (SALOME) ==> Mesh (SALOME) ==> use of python script salomeToOpenfoam (SALOME) ==> OpenFoam Good luck |
January 31, 2017, 08:23 |
#9 | |
Domi
Rep Power: 11 |
Hi aminem, thanks for this post. This is maybe actually the bug I´m dealing with. I set up a a simulation in OF 2.3.0 with chtMultiRegionSimpleFoam (convection + conduction + radiation), with a volumetric heat source and I have got a too slow convergence. All together I have 5 regions, whereas 2 are made with the extrudeToRegionMesh utility. May be the bug mentioned by you the reason for this extremely slow convergence? What kind of bug is it exactly? If you want, I can prepare my case folder for you, so that so can simulate it on your machine. Thanks a lot in advance. Best regards |
February 1, 2017, 03:17 |
#10 |
Tobias Holzmann
Rep Power: 52 |
Dear all,
I just want to sum up this topic for you and give some more information. First of all I have a question to @aminem: Do you have the bug-issue number of the problem you mentioned in OpenFOAM-2.3.0? I think it would be great to have it here, that everybody who is using an old OpenFOAM version can check it out and remove it. Convergence Domi, as I can see from your stats I think you are not really aware of the numerics behind, right? If I am wrong, sorry. However, the convergence of the problem should not come directly from a source term bug. Of course it can but based on the fact that I do not know the bug in detail, I cannot say that it is related to that. Keep in mind that we are solving the system in a segregated way. That means, all domains separately. That means, that you should have at least a few outer loop in order to correct the explicit terms and to get an accurate solution (if you are using a transient solver). For steady-state solvers it looks different (relaxation factors, etc.). In addition, a bad convergence can be related to:
In my personal opinion your bad convergence is related to one of the above mentioned points and not related to the source term. If you want to figure it out yourself, just remove your source and let it run (maybe set some other BC to get a well described problem). Keep in mind that I am not an expert in OpenFOAM and all related stuff, so I can be wrong too or it might be that I missed something.
Keep foaming, Tobias Holzmann |
Newton's Cooling | Nurzhan | CFX | 9 | December 11, 2014 01:04 |
Refrigerator Cooling circuit | rana18 | FLUENT | 1 | September 19, 2014 18:43 |
simpler way to model circuit board cooling | mihaipruna | OpenFOAM Running, Solving & CFD | 0 | May 8, 2013 15:34 |
Passive cooling system for batch reactor | Darek | Main CFD Forum | 0 | September 30, 2003 06:06 |
Temperature Distribution on a circuit board | Blackadder | Main CFD Forum | 1 | March 27, 2003 12:32 |
