April 1, 2015, 10:10 |
OpenFOAM Designer: OpenFOAM for windows
Amod Kumar
Rep Power: 16 |
Hello All,
I recently started using OpenFOAM, thanks to OpenFOAM modeler version and very nice videos on youtube, my learning curve accelerated. In order to share my experience and knowledge about OpenFOAM, I have summarized my findings at http://www.cfdyna.com/Home/OpenFOAM.html and http://www.cfdyna.com/Home/OpenFOAM_Tut.pdf Please let me know your comments to make it even better. Thanks and I hope this is of help to all, Amod |
April 2, 2015, 04:58 |
Christian
Rep Power: 12 |
Very interesting, will recommend to newbies!
June 17, 2015, 19:44 |
Running elbow case in windows with OpenFoam designer 1.5
ashley
Rep Power: 11 |
Hi Everyone,
I am very new to OpenFOAM and use openfoam designer in windows. So far I have managed to run the Cavity vase, but can not run the elbow case. I believe the elbow.msh in this tutorial should be changed to *.OpenFOAM but when I try mesh utilities<conversion< FluentmeshtoFoam it says the application not available. Is this how I make the *.OpenFOAM file? Is there any tutorial to run the elbow case with OpenFOAM designer? Many thanks, Ash |
June 19, 2015, 01:02 |
OpenFOAM designer in Windows
ashley
Rep Power: 11 |
Hi Everyone,
I am very new to OpenFOAM and use openfoam designer in windows 7. So far I have managed to run the Cavity case, but can not run the elbow case. I believe the elbow.msh in this tutorial should be changed to *.OpenFOAM but when I try mesh utilities<conversion< FluentmeshtoFoam it says the application not available. Is this how I make the *.OpenFOAM file? Is there any tutorial to run the elbow case with OpenFOAM designer? Many thanks, Ash |
openfoam, windows |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
[mesh manipulation] Creating an openfoam mesh for paraview using openfoam designer? | massive_turbulence | OpenFOAM Meshing & Mesh Conversion | 4 | August 29, 2014 04:11 |
ESI-OpenCFD Releases OpenFOAM v2.2.0 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 13 | March 30, 2013 16:52 |
OpenFoam Designer "tools" menu missing items | dsoodak | OpenFOAM | 2 | November 24, 2012 00:43 |
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x | wyldckat | OpenFOAM Bugs | 18 | October 21, 2010 05:51 |
