twoPhaseEulerFoam-bubble column case
Like Tree1Likes
  • 1 Post By chegdan
Old   November 19, 2014, 12:13
Default twoPhaseEulerFoam-bubble column case
Hamzeh
Hamzeh_Mirab is on a distinguished road
Hello everyone,
I wanna run bubble column with twophaseEulerFoam solver with my mesh. but these errors displayed in terminal.I attach my files.please guide me
MULES: Solving for alpha.air
alpha.air volume fraction = 0 Min(alpha1) = 0 Max(alpha1) = 0.5
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5 Foam::diameterModels::isothermal::d() const at ??:?
#6 Foam:haseModel::d() const at ??:?
#7 Foam:hasePair::Re() const at ??:?
#8 Foam::heatTransferModels::RanzMarshall::K() const at ??:?
#9 Foam::BlendedInterfacialModel<Foam::heatTransferMo del>::K() const at ??:?
#10 Foam::twoPhaseSystem::heatTransferCoeff() const at ??:?
#11
at ??:?
#12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13
at ??:?
Floating point exception (core dumped)
hamzeh@mirkhalili2:~/OpenFOAM/mirkhalili2-2.3.0/run/multiphase/twoPhaseEulerFoam/laminar/col2$
File Type: gz 0.tar.gz (1,020 Bytes, 25 views)
Hamzeh_Mirab is offline   Reply With Quote
Old   November 19, 2014, 12:20
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Try setting your pressure to something like 1e5 instead of 0. This zero pressure is causing divide by zero errors. Look more closely at the bubbleColumn tutorial and you will see that pressure is not zero. Hope this helps.
Hamzeh_Mirab likes this.
chegdan is offline   Reply With Quote
Old   November 19, 2014, 12:31
Hamzeh
Dear Chegdan
Thank you for your response. Thats right.Error fixed
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
bubble column ken FLUENT 1 June 30, 2013 02:18
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 09:59
simulation of a bubble column Pritika OpenFOAM 1 May 18, 2010 17:47
Boundary Conditions for Bubble Column cfd-novice FLUENT 0 April 14, 2003 02:50
