Rotating cylinder with fluid
Like Tree1Likes
  • 1 Post By wyldckat
Old   November 12, 2014, 14:15
Unhappy Rotating cylinder with fluid
Deutschland
Dhruval is on a distinguished road
hallo,
I need to do fluid simulation in Open Foam which I uploaded sketch..
in sketch I have one round drum which filled with fluid half and half is air (multiphase) and drum rotates in its axis. so which type of geometry should I use? hollow cylinder or solid cylinder?
and how can I give rotation to drum? does it change the mesh?
I thought to use VOF method to create fluid in cylinder as in (dam break Example) in set Field. so is it right? please guide me further or if anyone has same case then kindly upload it .
thanks
Dhruval is offline   Reply With Quote
Old   November 15, 2014, 11:42
Retired Super Moderator
Bruno Santos
Quick answer: Have a look into the "tutorials" folder, namely in the sub-folder "multiphase/interDyMFoam/ras": https://github.com/OpenFOAM/OpenFOAM...terDyMFoam/ras
Run the "sloshingTank*" tutorials and "testTubeMixer" tutorial and study how they are set-up.
Old   November 15, 2014, 11:46
Deutschland
thanks for reply but i need round cavity instead of square or cube.
so how can i give patches?
Old   November 15, 2014, 12:37
Bruno Santos
Quick answer: In the same tutorials sub-folder I mentioned, there is another tutorial named "mixerVesselAMI".
Old   November 15, 2014, 20:15
Deutschland
thanks.. i looked at this tutoriial also.. but i only need small roatating drum not whole mixer and i want this drum rotate itself.. so i have also STL or block-mesh file of cylinder
but i am sufuring difficulty to create fluid like damBreak so if you can guid me further it would be very helpful
Old   November 15, 2014, 22:15
Unhappy Problem whle simulation with changing geometry in dambreak
Deutschland
hi..i am trying to run multiphase/interFoam/laminar/damBreak example with changing geometry rectangle to round cylinder .. i did block mesh with cylinder patches -- works
but while simulation it gives error.. i am uploading my case , please try once and tell me problem.. thanks .
as i need same dam break example with change geometry..
Old   November 16, 2014, 18:25
Bruno Santos
Hi Dhruval,
Sorry, I was in a hurry the other day (still am today as well) and had hoped you would have tried to look into the other tutorial folders as well. The tutorial I had in mind was in fact "mixerVessel2D" and not "mixerVesselAMI". One such tutorial is "multiphase/MRFMultiphaseInterFoam/mixerVessel2D".
As for the case you attached, there are a few problems that I can see:
  1. The file "setFieldsDict" has the box incorrectly defined. You have this:
            box (0 1 0) (0.1461 0.292 1);
    Which is incorrect, because the first vector is meant to be the lower left-most corner.
    In your case, according to the "blockMeshDict" you have, the correct box should be something like:
            box (-0.01 -0.01 0.0) (0.01 0.0 1.0);
  2. The mesh will give you several headaches, because there are cells very small and distorted at some locations. Have a look at the tutorial I mentioned this time, namely "multiphase/MRFMultiphaseInterFoam/mixerVessel2D". It uses m4, which is explained in more detail here: http://openfoamwiki.net/index.php/Ho...ckMesh_with_m4
Beyond this, I didn't manage to find the time to see any more details.
Good luck! Best regards,
Bruno
Dhruval likes this.
Old   October 1, 2021, 14:53
Nasos_bal
Nasos_bal is on a distinguished road
Originally Posted by Dhruval View Post
hallo,
thanks
Did you find a solution?
Nasos_bal is offline   Reply With Quote
openfoam 2.1.1, rotating cylinder, snappy hex mesh
how to simulate a VIV of the cylinder in a fluid domian use rigid body solution? Mal CFX 13 April 14, 2014 14:44
Shaft rotating in fluid CHT Jonny6001 STAR-CCM+ 0 May 26, 2013 19:16
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
Vertical rotating cylinder Abhishek V FLUENT 0 December 16, 2006 17:20
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
