negative min.(alpha1) value interFoam
Like Tree3Likes
  • 2 Post By fabian_roesler
  • 1 Post By fabian_roesler
Old   October 19, 2014, 15:38
Default negative min.(alpha1) value interFoam
Arjun
Arjun Jayakumar is on a distinguished road
Hi...
I am new to openFoam, for the past week I am stuck with my problem. I am trying to simulate water falling on a circular tube surface. interFoam was selected as the base solver with dambreak as the base case.
slight modification were made with files of dambreak.
internalField was set as uniform 0. alpha.water for inlet as type fixedValue and value uniform 1. Wall B.C's as zeroGradient.
p_rgh B.C's
internalField uniform 0
walls as type fixedFluxPressure; value uniform 0;
inlet as type fixedValue; value uniform 0;
U B.C's
wall as type fixedValue; value uniform (0 0 0);
inlet as type flowRateInletVelocity; massFlowRate constant 0.1; rhoInlet 1;
setFields as
defaultFieldValues
volScalarFieldValue alpha.water 0
After some time steps min(alpha1) deviates to too negative value. the terminal shows
Time = 0.000215
smoothSolver: Solving for alpha.water, Initial residual = 0.135945, Final residual = 4.85033e-09, No Iterations 6
Phase-1 volume fraction = -3.89404e-14 Min(alpha1) = -0.494288 Max(alpha1) = 1
MULES: Correcting alpha.water
DICPCG: Solving for p_rgh, Initial residual = 0.421282, Final residual = 0.0204154, No Iterations 6
time step continuity errors : sum local = 9.04479e-07, global = -1.89978e-07, cumulative = -5.23877e-07
DICPCG: Solving for p_rgh, Initial residual = 0.304169, Final residual = 0.0149129, No Iterations 5
time step continuity errors : sum local = 8.80687e-07, global = -1.71627e-07, cumulative = -6.95504e-07
DICPCG: Solving for p_rgh, Initial residual = 0.244908, Final residual = 9.59156e-08, No Iterations 462
time step continuity errors : sum local = 6.22699e-12, global = -1.30827e-14, cumulative = -6.95504e-07
ExecutionTime = 3316.69 s ClockTime = 4119 s
Courant Number mean: 5.63527e-05 max: 5.31579
Interface Courant Number mean: 2.13444e-06 max: 2.08533
Time = 0.00022
smoothSolver: Solving for alpha.water, Initial residual = 0.173116, Final residual = 5.69664e-09, No Iterations 14
Phase-1 volume fraction = -5.2177e-14 Min(alpha1) = -0.70481 Max(alpha1) = 1
DICPCG: Solving for p_rgh, Initial residual = 0.381394, Final residual = 0.0167599, No Iterations 10
time step continuity errors : sum local = 1.58839e-06, global = -2.25771e-07, cumulative = -9.21275e-07
DICPCG: Solving for p_rgh, Initial residual = 0.271973, Final residual = 0.0121764, No Iterations 5
time step continuity errors : sum local = 1.32254e-06, global = -6.32625e-08, cumulative = -9.84538e-07
DICPCG: Solving for p_rgh, Initial residual = 0.191749, Final residual = 9.99155e-08, No Iterations 469
time step continuity errors : sum local = 1.11654e-11, global = 9.08119e-14, cumulative = -9.84538e-07
ExecutionTime = 3398.03 s ClockTime = 4207 s
Courant Number mean: 8.40514e-05 max: 8.08132
Interface Courant Number mean: 4.53269e-06 max: 4.24642
Time = 0.000225
smoothSolver: Solving for alpha.water, Initial residual = 0.170608, Final residual = 3.34717e-09, No Iterations 10
Phase-1 volume fraction = -1.10859e-13 Min(alpha1) = -0.56912 Max(alpha1) = 1
DICPCG: Solving for p_rgh, Initial residual = 0.418703, Final residual = 0.0192012, No Iterations 5
time step continuity errors : sum local = 2.23831e-06, global = -6.45109e-08, cumulative = -1.04905e-06
DICPCG: Solving for p_rgh, Initial residual = 0.264399, Final residual = 0.0117227, No Iterations 5
time step continuity errors : sum local = 1.56011e-06, global = 2.27227e-07, cumulative = -8.21821e-07
DICPCG: Solving for p_rgh, Initial residual = 0.161567, Final residual = 9.91333e-08, No Iterations 465
time step continuity errors : sum local = 1.33674e-11, global = -9.29279e-14, cumulative = -8.21821e-07
ExecutionTime = 3476.99 s ClockTime = 4294 s
Courant Number mean: 0.000106596 max: 9.31549
Interface Courant Number mean: 5.9444e-06 max: 3.21124
Time = 0.00023
smoothSolver: Solving for alpha.water, Initial residual = 0.174622, Final residual = 8.06469e-09, No Iterations 8
Phase-1 volume fraction = -1.36574e-13 Min(alpha1) = -1.08339 Max(alpha1) = 1
DICPCG: Solving for p_rgh, Initial residual = 0.563562, Final residual = 0.0271184, No Iterations 4
time step continuity errors : sum local = 3.22933e-06, global = -3.09184e-07, cumulative = -1.13101e-06
DICPCG: Solving for p_rgh, Initial residual = 0.325179, Final residual = 0.0159427, No Iterations 5
time step continuity errors : sum local = 2.12216e-06, global = -2.7194e-07, cumulative = -1.40295e-06
DICPCG: Solving for p_rgh, Initial residual = 0.218524, Final residual = 9.34715e-08, No Iterations 480
time step continuity errors : sum local = 1.2633e-11, global = 8.28896e-14, cumulative = -1.40295e-06
ExecutionTime = 3557.34 s ClockTime = 4382 s
Courant Number mean: 0.000124486 max: 9.14801
Interface Courant Number mean: 5.45008e-06 max: 1.54779
Time = 0.000235
smoothSolver: Solving for alpha.water, Initial residual = 0.203736, Final residual = 9.52402e-09, No Iterations 17
Phase-1 volume fraction = -3.94801e-13 Min(alpha1) = -0.606969 Max(alpha1) = 1
DICPCG: Solving for p_rgh, Initial residual = 0.110379, Final residual = 0.00435067, No Iterations 2
time step continuity errors : sum local = 9.18565e-06, global = -8.93057e-08, cumulative = -1.49225e-06
DICPCG: Solving for p_rgh, Initial residual = 0.0295617, Final residual = 0.00142974, No Iterations 5
time step continuity errors : sum local = 3.09834e-06, global = 3.46288e-07, cumulative = -1.14596e-06
DICPCG: Solving for p_rgh, Initial residual = 0.0228198, Final residual = 9.75055e-08, No Iterations 453
time step continuity errors : sum local = 2.164e-10, global = -9.17758e-13, cumulative = -1.14596e-06
ExecutionTime = 3635.92 s ClockTime = 4469 s
Courant Number mean: 0.000156587 max: 22.8963
Interface Courant Number mean: 7.49421e-06 max: 2.03706
Time = 0.00024
smoothSolver: Solving for alpha.water, Initial residual = 0.20387, Final residual = 3.9583e-09, No Iterations 13
Phase-1 volume fraction = 6.13117e-13 Min(alpha1) = -4.09164 Max(alpha1) = 1
DICPCG: Solving for p_rgh, Initial residual = 0.749905, Final residual = 0.0333727, No Iterations 9
time step continuity errors : sum local = 9.46227e-06, global = -3.61406e-06, cumulative = -4.76002e-06
DICPCG: Solving for p_rgh, Initial residual = 0.307627, Final residual = 0.01456, No Iterations 6
time step continuity errors : sum local = 6.64208e-06, global = -1.50695e-06, cumulative = -6.26697e-06
DICPCG: Solving for p_rgh, Initial residual = 0.160218, Final residual = 9.90744e-08, No Iterations 489
time step continuity errors : sum local = 4.83966e-11, global = 2.85499e-13, cumulative = -6.26697e-06
ExecutionTime = 3718.94 s ClockTime = 4560 s
Courant Number mean: 0.000414007 max: 145.401
Interface Courant Number mean: 9.92862e-06 max: 5.30545
Time = 0.000245
smoothSolver: Solving for alpha.water, Initial residual = 0.426234, Final residual = 8.67918e-09, No Iterations 50
Phase-1 volume fraction = -6.7424e-14 Min(alpha1) = -5.62255 Max(alpha1) = 1
Phase-1 volume fraction = -6.7424e-14 Min(alpha1) = -5.54044 Max(alpha1) = 1.9061
DICPCG: Solving for p_rgh, Initial residual = 0.801868, Final residual = 0.0396942, No Iterations 4
time step continuity errors : sum local = 2.10043e-05, global = -7.37201e-06, cumulative = -1.3639e-05
DICPCG: Solving for p_rgh, Initial residual = 0.166809, Final residual = 0.00802116, No Iterations 6
time step continuity errors : sum local = 2.94754e-05, global = -1.06916e-05, cumulative = -2.43305e-05
exit
DICPCG: Solving for p_rgh, Initial residual = 0.330884, Final residual = 9.89421e-08, No Iterations 501
time step continuity errors : sum local = 3.14305e-10, global = 6.02658e-13, cumulative = -2.43305e-05
ExecutionTime = 3811.48 s ClockTime = 4667 s
Courant Number mean: 0.00181847 max: 479.069
Interface Courant Number mean: 0.000605703 max: 479.069
Time = 0.00025
smoothSolver: Solving for alpha.water, Initial residual = 0.702312, Final residual = 9.28023e-09, No Iterations 66
Phase-1 volume fraction = -3.41965e-12 Min(alpha1) = -18.9554 Max(alpha1) = 1
Phase-1 volume fraction = -3.41965e-12 Min(alpha1) = -15.4267 Max(alpha1) = 6.79324
DICPCG: Solving for p_rgh, Initial residual = 0.563373, Final residual = 0.0229745, No Iterations 5
time step continuity errors : sum local = 4.96062e-05, global = -1.45167e-05, cumulative = -3.88473e-05
really confused with what to do?
Thanks in advance.
Arjun Jayakumar is offline   Reply With Quote
Old   October 20, 2014, 03:54
Fabian Roesler
fabian_roesler is on a distinguished road
From the first glimpse I'd say you miss an outlet boundary. But I can't tell for sure until you post your p_rgh an U files. You let water flow into a domain. As for interFoam, all phases including gas/air are incompressible, some material has to leave the domain to fulfill continuity. Add an atmosphere at the top or an outlet boundary at the bottom of your domain.
Cheers
Fabian
Arjun Jayakumar and mizzou like this.
fabian_roesler is offline   Reply With Quote
Old   October 20, 2014, 04:38
Arjun
Dear Fabian,
Thanks for your time....
My p_rgh...
internalField uniform 0;
boundaryField
WALL
value uniform 0;
TUBEWALL
value uniform 0;
INLET
value uniform 0;
OUTLET
type totalPressure;
value uniform 0;
p0 uniform 0;
U U;
phi phi;
gamma 1;
value uniform 1;
FRONTANDBACK
value uniform 0;
U file...
internalField uniform (0 0 0);
boundaryField
WALL
type fixedValue;
TUBEWALL
type fixedValue;
INLET
type fixedValue;
value uniform (0 0.03 0);
OUTLET
type pressureInletOutletVelocity;
FRONTANDBACK
type fixedValue;
thanks in advance
Old   October 20, 2014, 05:38
Fabian Roesler
So now I see, that you have an atmosphere boundary condition. So my first guess was wrong. But I also see, that your Courant number is quite big for multi phase simulations with interFoam. Could you post a picture of your simulation domain and the mesh you use? You could try to increase the nonOrthCorrectors and do a checkMesh to see if your mesh is sufficient for simulation.
mizzou likes this.
Old   October 20, 2014, 05:42
Fabian Roesler
An one more question! Do you use fixed time steps? This could be the reason for the high Courant number. Change adjustTimeSteps to true in controlDict.
Old   October 20, 2014, 06:23
Arjun
Dear Fabian,
checkMesh will give....
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 1658928
internal faces: 1571476
cells: 807601
faces per cell: 4
boundary patches: 7
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 807601
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
INLET 2995 1595 ok (non-closed singly connected)
WALL 9201 4856 ok (non-closed singly connected)
SPLITWALL 16917 8651 ok (non-closed singly connected)
FRONTANDBACK 28636 15114 ok (non-closed singly connected)
TUBEWALL 14408 7572 ok (non-closed singly connected)
SYMMETRY 9446 4942 ok (non-closed singly connected)
OUTLET 5849 3101 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (0 0 0) (20 35.4 10)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (1.87929e-15 -7.48659e-16 -1.06194e-16) OK.
Max cell openness = 2.68207e-16 OK.
Max aspect ratio = 5.77614 OK.
Minimum face area = 0.00152086. Maximum face area = 0.682333. Face area magnitudes OK.
Min volume = 3.19342e-05. Max volume = 0.158068. Total volume = 4547.61. Cell volumes OK.
Mesh non-orthogonality Max: 56.2501 average: 14.9404
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.646766 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Snapshots of mesh
currently i am working with fixed time step. a dynamic time step is leading to very small time step.
thanks
Old   October 20, 2014, 06:58
Fabian Roesler
That's the point. you have to keep Co below 1 even if this leads to small dT. I see you have a tet-Mesh. So I'd increase the nonOrth correctors to 2 and use adjustTimeStep. This should solve your problems.
Cheers
Fabian
Old   October 20, 2014, 07:17
Arjun
Dear Fabian,
Currently working with adjusttimestep. time step in the order of e-6....will update the results soon,
Thanks
Arjun
Old   October 21, 2014, 07:35
Arjun
Dear Fabian,
Carried out simulations for 0.008 seconds. The results obtained are confusing. It looks like no flow have happened. velocity and pressure ranges are so high after 0.008 seconds.
4.jpg alpha
5.jpg pressure
6.jpg velocity
I doubt some thing have gone wrong with the boundary condition. Please have a look at the B.C's posted in earlier comment. only variation made from above is that of outlet velocity where I have used
OUTLET
type fluxCorrectedVelocity;
phi phi;
rho rho;
Since I am unsure of the velocity at outlet.
Thanks in advance
Arjun
Old   October 21, 2014, 08:33
Fabian Roesler
Have you increased the nonOrth correctos? As you have a tet mesh you should adapt your fvSchemes and fvSolution. And moreover, as you have a small inlet velocity of 0.03 m/s, the phase will only travel 0.00024 m in the first 0.008 s. I guess your mesh is not that fine.
Old   October 21, 2014, 08:42
Arjun
Dear Fabian,
Yes I have increased the nNonOrthogonalCorrectors to 2. I agree that the time for which simulation have done is too low but why i am i getting high pressure and velocity range, also alpha is still appreciably negativeand becomes more negative with time step.
Thanks in advance
Arjun
Old   December 21, 2019, 11:59
Default Query regarding interFOAM
  #12
Usama Niaz
Niazi is on a distinguished road
I am using interFOAM for the simulation of flow through injector. While monitoring the values, the value of alpha min was getting more and more negative with each time step, I tried with different FVSCHEMES and FVSOLUTIONS but the effects weren't such satisfactory. I am confused about the results can anyone please help? I am attaching all the necessary files. Thanks in advance.
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alpha.water;
dimensions [0 0 0 0 0 0 0];
boundaryField
INLET
type fixedValue;
value uniform 1;
OPENING
type inletOutlet;
inletValue uniform 0;
value uniform 0;
WALL
type zeroGradient;
ATMOPSHERE
type inletOutlet;
value uniform 0;
OUTFLOW
type zeroGradient;
FoamFile
version 2.0;
format ascii;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
INLET
type fixedValue;
value uniform 25;
OPENING
type totalPressure;
p0 uniform 0;
phi phi;
U U;
rho rho;
psi none;
gamma 1;
value uniform 0;
WALL
type zeroGradient;
OUTFLOW
type totalPressure;
p0 uniform 0;
phi phi;
U U;
rho rho;
psi none;
gamma 1;
value uniform 0;
ATMOPSHERE
type totalPressure;
p0 uniform 0;
phi phi;
U U;
rho rho;
psi none;
gamma 1;
value uniform 0;
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 -1);
boundaryField
INLET
type pressureDirectedInletOutletVelocity;
phi phi;
rho rho;
inletDirection uniform (0 0 -1);
OPENING
type inletOutlet;
inletValue uniform (0 0 0);
WALL
type noSlip;
OUTFLOW
type zeroGradient;
ATMOPSHERE
type inletOutlet;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
default cellLimited Gauss linear 1;
grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(rhoPhi,U) Gauss upwind;
div(phi,alpha) Gauss upwind;
div(phirb,alpha) Gauss upwind;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited 0.5;
interpolationSchemes
default linear;
snGradSchemes
default limited 0.5;
oamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"alpha.water.*"
nAlphaCorr 3;
nAlphaSubCycles 1;
cAlpha 1;
MULESCorr yes;
nLimiterIter 10;
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-8;
relTol 0;
"pcorr.*"
solver PCG;
preconditioner DIC;
tolerance 1e-5;
relTol 0;
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-07;
relTol 0.05;
p_rghFinal
$p_rgh;
relTol 0;
U
tolerance 1e-06;
relTol 0;
PIMPLE
momentumPredictor no;
nOuterCorrectors 1;
nCorrectors 3;
nNonOrthogonalCorrectors 0;
relaxationFactors
equations
".*" 1;
IMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 2.39905e-06, Final residual = 2.49417e-09, No Iterations 1
Phase-1 volume fraction = 3.08796e-07 Min(alpha.water) = -470.128 Max(alpha.water) = 1.00001
DILUPBiCGStab: Solving for Ux, Initial residual = 8.49933e-05, Final residual = 6.06912e-10, No Iterations 2
DILUPBiCGStab: Solving for Uy, Initial residual = 0.000126589, Final residual = 1.28378e-09, No Iterations 2
DILUPBiCGStab: Solving for Uz, Initial residual = 0.000199473, Final residual = 5.30592e-10, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.000339389, Final residual = 3.32711e-06, No Iterations 61
DICPCG: Solving for p_rgh, Initial residual = 0.000133497, Final residual = 1.32885e-06, No Iterations 31
time step continuity errors : sum local = 1.63418e-11, global = -2.09633e-12, cumulative = 6.05599e-10
DICPCG: Solving for p_rgh, Initial residual = 0.000110693, Final residual = 1.05488e-06, No Iterations 29
DICPCG: Solving for p_rgh, Initial residual = 1.82509e-05, Final residual = 8.94744e-07, No Iterations 4
time step continuity errors : sum local = 1.11345e-11, global = -1.95497e-12, cumulative = 6.03644e-10
DICPCG: Solving for p_rgh, Initial residual = 2.85582e-05, Final residual = 9.53669e-07, No Iterations 13
DICPCG: Solving for p_rgh, Initial residual = 6.08945e-06, Final residual = 8.72447e-07, No Iterations 2
time step continuity errors : sum local = 1.08846e-11, global = -1.19801e-12, cumulative = 6.02446e-10
ExecutionTime = 3128.16 s ClockTime = 3129 s
Courant Number mean: 1.40749e-05 max: 1.00109
Interface Courant Number mean: 1.62036e-07 max: 0.344919
deltaT = 4.80404e-05
Time = 0.0615891
PIMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 2.40007e-06, Final residual = 2.51251e-09, No Iterations 1
Phase-1 volume fraction = 3.09089e-07 Min(alpha.water) = -472.352 Max(alpha.water) = 1.00001
DILUPBiCGStab: Solving for Ux, Initial residual = 8.28728e-05, Final residual = 8.10431e-10, No Iterations 2
DILUPBiCGStab: Solving for Uy, Initial residual = 0.000132246, Final residual = 2.79118e-10, No Iterations 2
DILUPBiCGStab: Solving for Uz, Initial residual = 0.000198283, Final residual = 5.72642e-10, No Iterations 2
DICPCG: Solving for p_rgh, Initial residual = 0.000394632, Final residual = 3.91978e-06, No Iterations 62
DICPCG: Solving for p_rgh, Initial residual = 0.000129692, Final residual = 1.27055e-06, No Iterations 23
time step continuity errors : sum local = 1.78135e-11, global = 2.21176e-12, cumulative = 6.04658e-10
DICPCG: Solving for p_rgh, Initial residual = 9.62398e-05, Final residual = 9.99713e-07, No Iterations 33
DICPCG: Solving for p_rgh, Initial residual = 2.37526e-05, Final residual = 8.63825e-07, No Iterations 4
time step continuity errors : sum local = 1.19287e-11, global = 3.90686e-12, cumulative = 6.08565e-10
Niazi is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
