modeling Multi-component, multi-phase flow with Cahn Hilliard equation
Like Tree1Likes
  • 1 Post By nero235
Old   June 16, 2014, 13:52
Default modeling Multi-component, multi-phase flow with Cahn Hilliard equation
hossein
hosein67 is on a distinguished road
Hello every one,
I'am going to do a simulation on Solvent-based thin-film deposition. An initially homogeneous mixture separates into conjugated polymer and a fullerene derivative as the solvent evaporates.
The solvent evaporates into the atmosphere and we assume that it evaporates uniformly from the top surface and film height decreases homogeneously.
I want to use phase field approach by solving Cahn–Hilliard equation to describe the behavior of multicomponent system with various driving forces.
Does any body has such experience in OpenFoam or any advices, references or tutorials which can help me.
Thank you in advance.
Regards,
Hossein
hosein67 is offline   Reply With Quote
Old   July 24, 2014, 17:00
Sebastian W.
nero235 is on a distinguished road
Send a message via ICQ to nero235
Originally Posted by hosein67 View Post
Hello every one,
Regards,
Hossein
Hi Hossein,
the Cahn-Hilliard model is currently not implemented in OF. However I am working on a solver to simulate phase separation. As far as I know the only codes available to do that is COMSOL and a finite volume PDE solver based on Python called "fipy". fipy doesn't account for convective transport though. Hope this helps!
Regards, Sebastian.
hosein67 likes this.
nero235 is offline   Reply With Quote
Old   September 11, 2014, 23:02
hossein
Dear Sebastian,
Your suggestion about FiPy help me a lot. I am working on it. Thank you so much for that.
Regards,
Hossein
Old   November 4, 2014, 16:00
Albrecht vBoetticher
vonboett is on a distinguished road
well, Dr. Keller at TU Freiberg did a VOF based solver for binary mixture evaporation and break up: http://www.personal.psu.edu/dab143/O...ler_slides.pdf
vonboett is offline   Reply With Quote
2 phase flow equation in 1D Nicolas Main CFD Forum 0 December 13, 2003 15:19
2 phase flow equation Nicolas Main CFD Forum 0 December 13, 2003 15:16
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 10:21
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
