May 14, 2014, 11:34 |
Unknown topoSetSource type expressionToFace
Marcus Letzel
Rep Power: 14 |
Dear Foamers,
when I execute topoSet in my case directory, with this system/topoSetDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ( "libsampling.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" "libswakTopoSources.so" ); actions ( { name durchflussmesserFaces; type faceSet; action new; source expressionToFace; sourceInfo { expression "fpos().z>17.9 && fpos().z<18.1 && sqrt(pow(fpos().x,2)+ pow(fpos().y,2))<62.55"; } } { name durchflussmesserFacesSlaveCells; type cellSet; action new; source boxToCell; sourceInfo { box ( -100 -100 0 ) ( 100 100 18.0 ); } } ); // ************************************************************************* // Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.2-9240f8b967db Exec : /opt/openfoam222/platforms/linux64GccDPOpt/bin/topoSet Date : May 14 2014 Time : 16:26:18 Host : [...] PID : 31428 Case : [...] sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0.2 Reading topoSetDict Time = 0.2 mesh not changed. Created faceSet durchflussmesserFaces Applying source expressionToFace --> FOAM FATAL ERROR: Unknown topoSetSource type expressionToFace Valid topoSetSource types : 43 ( boundaryToFace boxToCell boxToFace boxToPoint cellToCell cellToFace cellToPoint cylinderAnnulusToCell cylinderToCell faceToCell faceToFace faceToPoint faceZoneToCell faceZoneToFaceZone fieldToCell labelToCell labelToFace labelToPoint nbrToCell nearestToCell nearestToPoint normalToFace patchToFace pointToCell pointToFace pointToPoint regionToCell regionToFace rotatedBoxToCell searchableSurfaceToFaceZone setAndNormalToFaceZone setToCellZone setToFaceZone setToPointZone setsToFaceZone shapeToCell sphereToCell surfaceToCell surfaceToPoint targetVolumeToCell zoneToCell zoneToFace zoneToPoint ) From function topoSetSource::New(const word&, const polyMesh&, const dictionary&) in file sets/topoSetSource/topoSetSource.C at line 89. FOAM exiting I would be grateful for any suggestions how to solve this error. Cheers, Marcus |
May 15, 2014, 11:30 |
Marcus Letzel
Rep Power: 14 |
...I'd like to solve this issue, so if you require more information from me that is not clear or missing from my first post, please let me know.
Thanks a lot in advance, Marcus |
May 16, 2014, 07:29 |
swak4foam: Parser Error for driver FieldValueExpressionDriver
Marcus Letzel
Rep Power: 14 |
Happy to report that the initial problem was solved by adding
libs ( "libswakTopoSources.so" ); This was, however, followed by another error: Code:
Created faceSet durchflussmesserFaces Applying source expressionToFace Adding all elements of for which "fpos().z>17.9 && fpos().z<18.1 && sqrt(pow(fpos().x,2)+ pow(fpos().y,2))<62.55" evaluates to true ... --> FOAM FATAL ERROR: Parser Error for driver FieldValueExpressionDriver at "1.10-13" :"syntax error, unexpected number" "fpos().z>17.9 && fpos().z<18.1 && sqrt(pow(fpos().x,2)+ pow(fpos().y,2))<62.55" ^^^^ -----------| Context of the error: - Driver constructed from scratch Evaluating expression "fpos().z>17.9 && fpos().z<18.1 && sqrt(pow(fpos().x,2)+ pow(fpos().y,2))<62.55" From function parsingValue in file lnInclude/CommonValueExpressionDriverI.H at line 1081. FOAM exiting |
May 16, 2014, 09:34 |
Marcus Letzel
Rep Power: 14 |
Following this post (thanks, Bernhard!), I solved the my problem by applying interpolate() to 17.9, 18.1 and 62.55. The respective formula now reads:
expression "fpos().z>interpolate(17.9) && fpos().z<interpolate(18.1) && sqrt(pow(fpos().x,2)+ pow(fpos().y,2))<interpolate(62.55)"; |
swak4foam, toposetdict |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 17:14 |
Simulation of Radial Fan with simpleFoam MRF | nash | OpenFOAM Running, Solving & CFD | 2 | November 5, 2015 11:12 |
Thermal Comfort Simulation in STAR CCM+ | anupmu | STAR-CCM+ | 1 | February 27, 2013 15:25 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 16:46 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
