interfoam:a problem with Air-phase convective-term treatment
Like Tree2Likes
  • 2 Post By Phicau
Old   March 31, 2014, 03:10
Exclamation interfoam:a problem with Air-phase convective-term treatment
xuhe-openfoam
bieshuxuhe is on a distinguished road
hello!
i modify the convective-term of the UEqn of interfoam. the "alpha1" is volume fraction!
there are two ways that i test.
the first way:
fvVectorMatrix UEqn
fvm::ddt(rho, U)
+ alpha1*fvm::div(rhoPhi, U)
+ turbulence->divDevRhoReff(rho, U)
and, type "wmake" in the terminal. then , i success !
the second way:
fvVectorMatrix UEqn
fvm::ddt(rho, U)
+ (fvm::div(rhoPhi, U))*alpha1
and type "wmake" in the terminal. then , i failed !!!
there are some information come out in the terminal:
/home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvMatrix.C:2293:34: 附注: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::operator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::fvMatrix<Type> >&)
/home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvMatrix.C:2293:34: 附注:   template argument deduction/substitution failed:
In file included from interFoam.C:90:0:
UEqn.H:4:31: 附注:   cannot convert ‘Foam::fvm::div(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Vector<double>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]((*(const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*)(& U)))’ (type ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’) to type ‘const Foam::dimensioned<double>&’
In file included from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/one.H:64:0,
                 from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvmDdt.H:40,
                 from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvm.H:43,
                 from /home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/fvCFD.H:10,
                 from interFoam.C:40:
/home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/oneI.H:36:20: 附注: template<class Type> const Type& Foam::operator*(const Type&, const Foam::one&)
/home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/oneI.H:36:20: 附注:   template argument deduction/substitution failed:
UEqn.H:4:31: 附注:   cannot convert ‘alpha1’ (type ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’) to type ‘const Foam::one&’
/home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/oneI.H:42:20: 附注: template<class Type> const Type& Foam::operator*(const Foam::one&, const Type&)
/home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/oneI.H:42:20: 附注:   template argument deduction/substitution failed:
UEqn.H:4:31: 附注:   cannot convert ‘Foam::fvm::div(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::Vector<double>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]((*(const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>*)(& U)))’ (type ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’) to type ‘const Foam::one&’
In file included from interFoam.C:61:0:
/home/sxh/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/readTimeControls.H:38:8: 警告: 未使用的变量‘maxDeltaT’ [-Wunused-variable]
make: *** [Make/linux64GccDPOpt/interFoam.o] 错误 1
sxh@sxh-virtual-machine:~/OpenFOAM/sxh-2.2.0/project/fsi/src/xuheinterFoam$
could you help me ? why the second way is wrong ?
thanks!
bieshuxuhe is offline   Reply With Quote
Old   March 31, 2014, 03:44
Pablo Higuera
Phicau is on a distinguished road
Hi Xuhe,
fvm:: corresponds to the implicit part, i.e. the U matrix coefficients. Although both ways should work in theory, only the first one is defined programmatically.
Best,
Pablo
vsammartano and bieshuxuhe like this.
Phicau is offline   Reply With Quote
Old   March 31, 2014, 03:52
xuhe-openfoam
thank you !
interfoam;ueqn
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
Thermal phase change set up problem Danial Q Main CFD Forum 1 July 10, 2014 15:41
Two phase flow problem jignesh_thaker2007 OpenFOAM 2 August 2, 2012 17:59
two phase reaction problem pan_zh OpenFOAM Programming & Development 0 February 6, 2012 00:50
Help - Two Phase Flow - Convergence Problem R.Sureshkumar Main CFD Forum 1 February 22, 2000 04:24
