September 17, 2013, 08:41 |
mut and alphat & compressible flow
Sasan Ghomi
Rep Power: 15 |
Hi foamers ,
I have a question about setting mut and alphat file in the 0 directory . I checked rhopimpleFoam tutorial . In this case all values of mut and alphat on the walls are 0 . type mutwallFunction; ------> for mut value uniform 0; type alphatwallFunction; ------> for alphat value uniform 0; Also I checked kEpsilon.C in this source code I found a formula for calculating mut and alphat . mut_ = Cmu_*rho_*sqr(k_)/epsilon_; alphat_ = mut_/Prt_; I want to create a case by coldEngineFoam . So I should set mut and alphat file and I am confusing about setting these files. Please anybody guide me. I should set uniform 0 for them or I should calculate them by using their formula . Why in the tutorial the values have set uniform 0 ?? I appreciate any help from you. Thanks and best regards, Sasan. |
September 17, 2013, 13:54 |
Nima Samkhaniani
Rep Power: 25 |
as much as i know , when you are using wall function, the value is place holder! so that value is not important and the value of variable will be calculated based upon correlation
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
September 17, 2013, 15:42 |
Sasan Ghomi
Rep Power: 15 |
Dr.Sam
Thank you very much for your reply. |
Free jet simulation | msarkar | OpenFOAM Running, Solving & CFD | 39 | May 11, 2021 14:21 |
an odd(at least for me!) reconstructPar error on a field | immortality | OpenFOAM Running, Solving & CFD | 3 | June 3, 2013 23:36 |
XiFoam floating point error..mut error? | achinta | OpenFOAM | 8 | July 31, 2012 05:48 |
laminar pipe flow with buoyantSimpleRadiationFoam and janafThermo crashes | Fabian | OpenFOAM | 1 | September 29, 2010 12:38 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 05:53 |
