Numerical simulation of DBD plasma actuator induced flow
Like Tree1Likes
  • 1 Post By PonchO
Old   September 15, 2013, 22:16
Lightbulb Numerical simulation of DBD plasma actuator induced flow
Mominul MuKuT
mukut is on a distinguished road
Earlier time, I have used PHOENICS to simulate flow induced by Plasma Actuator (PA). Now my target is to implement openFoam in PA induced flow simulation and later which will be coupled with plasma vortex generator induced flow simulation. As a three months user of openFoam, I am still struggling to learn, so in this regard all of your support is cordially welcomed. Possibly I have to use solver pisoFoam/potentialFoam for my purpose. Does anybody has experience to simulate PA induced flow by openFoam? I have only 2months to complete this simulation, till I am in deep sea
mukut is offline   Reply With Quote
Old   September 20, 2013, 05:23
Christoph Kratzsch
PonchO is on a distinguished road
Hi mukut,
i don't have experience with plasma actuators. So i don't know about the plasma physics. But i'm analyzing a flow control problem too. In my case it is realized by Lorentz-forces acting on the flow.
I think you want to add an extra volumeforce inside an existing solver like pisoFoam, am i right?
Best regards.
PonchO is offline   Reply With Quote
Old   September 20, 2013, 05:30
Mominul MuKuT
Originally Posted by PonchO View Post
Hi mukut,
Best regards.
Hello PonchO,
thanks for your reply. Yes, something like that....in plasma actuator it is necessary to couple body force with velocity...
Old   September 20, 2013, 05:51
Christoph Kratzsch
I don't know if it helps:
In pisoFoam.C you have something like this:
fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
              + turbulence->divDevReff(U)
So you can define a force before the UEqn is evaluated:
volVectorField lorentz = sigma * (-fvc::grad(PotE) ^ B0) + sigma * ((U ^ B0) ^ B0);
Now you can add them to the equation in the UEqn
fvVectorMatrix UEqn
            fvm::ddt(U)
            + fvm::div(phi, U)
            (1.0/rho) * lorentz    // Lorentz force term
After the Fields are calculated and after the PISO-loop you can add subsequent formula for describing the distribution of your additional force. In my case it were realized by an extra outer loop for the lorentz-force calculation.
Is that kind of something you want to do?
Best regards,
Christoph
babala likes this.
Old   September 20, 2013, 05:59
Mominul MuKuT
fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
fvVectorMatrix UEqn
            fvm::ddt(U)
            + fvm::div(phi, U)
Best regards,
Christoph
Thanks for your good effort. I want to do something like this image
I am a new user, previous time I simulated flow induced by PA in phoenics but now I don't understand how to define actuator inside flow domain. Is it possible to define such configuration using default mess generation by openFoam?
Old   January 7, 2014, 06:30
Vincent RIVOLA
vinz is on a distinguished road
hello MominulDid you manage to model your plasma actuator in OpenFoam
I am planning to work on the same subject in comming weeks.
vinz is offline   Reply With Quote
numerical simulation, openfoam, plasma actuator modeling
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 12:46
Wing lift in Solidwork Flow Simulation brianmcv Main CFD Forum 6 April 11, 2011 09:16
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
Solid-Liquid Two Phase Flow Numerical Simulation with the Finite Element Method Qing Hao Main CFD Forum 2 January 9, 1999 00:31
