Porblem in running openFOAM Tutorial.
Like Tree1Likes
  • 1 Post By cutter
Old   September 6, 2013, 04:57
Lightbulb Porblem in running openFOAM Tutorial.
Mominul MuKuT
mukut is on a distinguished road
Dear all,
I am a new user of openFoam and I started to learn this open CFD tool box since last months. I have successfully run some incompressible flow related tutorials like cavity and cavityfine case. Now I have tried to run cavityHighRe case by following instructions given in user manual. I have made necessary change in ControlDict file and decrease kinematic viscosity to increase Re.
Then I ran paraFoam to make contour, streamline plots.....etc.
but contour of P shows 0 values like attached image. What's the problem? May be it is a very silly mistake but as I am a new user plz help to find out the faults.
Thanks
mukut is offline   Reply With Quote
Old   September 6, 2013, 04:59
Default icoFoam execution...
Mominul MuKuT
no need to display
Default remaining part
Mominul MuKuT
no need to display
Old   September 6, 2013, 05:17
cutter is on a distinguished road
In your screenshot above you visualize the intial state only. Did you try to load the later steps (green buttons on the upper toolbar)?! You then might also want to rescale to the data range (third button in the second toolbar row).
Cutter
RichJoe likes this.
cutter is offline   Reply With Quote
Old   September 6, 2013, 05:21
Talking
Mominul MuKuT
thank u so much. I got it.
Old   September 6, 2013, 05:37
Mominul MuKuT
Dear admin,
My problem is solved. Please delete this post.
thanks.
Old   September 6, 2013, 08:03
no problem, we've all had our problems when starting with OF and Paraview.
Please keep the discussion to the forums. There's also no need to delete stuff - other beginners might also profit from previous questions.
Paraview provides a huge amount of filters and settings. Try to apply and combine different filters to get a grasp of how thinks work. This might take some hours. For your particular case you could first apply a cut plane (fourth button of last toolbar row) and then create the glyphs for the vector field on this plane (select plane in the tree on the left, apply glyph filter). Good luck!
Cutter
cfd, contour plot, incrompressible, openfoam, parafoam
OpenFOAM: looking for advice and compressible, nonisothermal tutorial preparation bzz77 CFD Freelancers 1 February 2, 2016 13:11
Elbow tutorial from fluent in OpenFOAM inf.vish OpenFOAM Running, Solving & CFD 0 July 31, 2013 03:21
Running OpenFOAM on Rescale um-engineer OpenFOAM Running, Solving & CFD 0 September 26, 2012 02:01
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
