writePrecision has any effect in accuracy?
Like Tree3Likes
  • 2 Post By Bernhard
  • 1 Post By immortality
Old   August 12, 2013, 02:43
Default writePrecision has any effect in accuracy?
immortality's Avatar
Ehsan
immortality is on a distinguished road
does writePrecision has any effect on results or its only for representation of numbers to the user? which value is better?
writePrecision  10;
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   August 12, 2013, 04:12
Hrushi
hrushi.397 is on a distinguished road
I think it does. Since the NS equ is non-linear, it will amplify the errors if they are introduced due to precision, particularly if you are solving a problem with turbulence.
hrushi.397 is offline   Reply With Quote
Old   August 12, 2013, 04:36
cutter is on a distinguished road
In my understanding it has no effect on the internal accuracy during the solution process. The effects described in the previous post should only occur when starting from a state that has been written to disk with a lower precision.
cutter is offline   Reply With Quote
Old   August 12, 2013, 05:17
Ehsan
thanks both Hrushi and Cutter
then if I improve writePrecision from 10 to 12 for example does the results become more accurate(because of more significant figures)? or it produce some amplifying errors in return?
my case is unsteady turbulent and compressible,which value you suggest?
Old   August 12, 2013, 05:23
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
you should always use binary format and then the writePrecision is just for presentation and has no effect.
If you have ascii format and perform a parallel calculation you should be aware that the processore to processor communication is streamed via the Pstream library and thus the precision can be influential,
but Im not sure.
niklas is offline   Reply With Quote
Old   August 12, 2013, 05:39
Ehsan
Hi Niklas
thanks,I need to make some changes in variables(around each 500000 iterations)in groovyBC during run so it seems I can't use binary files unless there is a way to convert binary files need to change to ascii ones so that performing modifications can be done.
how can see which value is specified for Pstream?
what value is better in your opinion?
what may be its other effects? it causes to take more space on disc and more run time too?
Old   August 12, 2013, 05:49
niklas's Avatar
Niklas Nordin
i suggest you perform a simple parallel run test on one of the tutorials and
test with 2 different values on writePrecision
for instance 3 and 12
if the results differ...then you know
Old   August 12, 2013, 05:57
Ehsan
OK
does it account for all the digits or digits after points?
for example if a number is 12345.111 and writePrecision be 5 it will included in calculations with 12345? isn't there away so that we can specify number of digits after "."?
Old   August 12, 2013, 10:45
Bernhard
Bernhard is on a distinguished road
Consider foamFormatConvert
Bernhard is offline   Reply With Quote
Old   August 13, 2013, 05:08
Ehsan
Hi
It seems a bit tricky.in variables like pressure and temperature that a multi-diagonal matrix is solved for them it seems that writePrecision has not much effect BUT in rho that is calculated from other fields by perfect gas equation it is important.
I tested rhoCentralFoam/forwardStep for two different writePrecisions 2 and 12.
these are writePrecisions 2; results:
cfdonline2mohsen likes this.
Old   August 13, 2013, 05:12
Ehsan
due to limitation of numbers of attachments(5) I put writePrecision=5 results here.
correct if my conclusion isn't true.
I appreciate for other comments and experiments.
Accuracy of wall shear and velocity kjetil OpenFOAM Running, Solving & CFD 10 April 27, 2010 14:35
Temporal accuracy ganesh Main CFD Forum 0 February 29, 2008 06:32
effect of order of temporal accuracy zonexo Main CFD Forum 4 August 14, 2006 01:36
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
accuracy of Discontinuous Galerkin Qu Kun Main CFD Forum 0 September 6, 2004 10:19
