what is correct boundary condition for K-w sst model at y+<1? |
Rep Power: 15 ![]() |
Hi
I found some thread about k-w sst boundary conditions unfortunately they are not clear in low y+ please let me know what is correct boundary conditions for k, w and nut for y+<5 Best Regards |
Andre Weiner
Rep Power: 14 ![]() |
Hello!
omega: Menter's automatic wall funcion works for all parts of the momentum boundary layer, in openfoam it's the omegaWallFunction http://www.cfd-online.com/Wiki/Near-...k-omega_models or you use the solution for the viscos sublayer to set the boundary value http://turbmodels.larc.nasa.gov/sst.html (there is an equation for omega_wall) for y^+<5 both give the same results k: fixed value 0 or zero gradient if you look at same results for k near the wall (from other simulations for example), you will see that both are valid (again for y^+<5) nut: calculated or fixed value 0 or nutLowReWallFunction (sets the value to zero and provides a function for calculating y^+ which is needed for the yPlusRAS tool) This is what i tried so far and it worked for mi :-) Best regards, Andre |
#3 | |
what function should be set for calculating y+ ? and how set it ? can you attached an example for k,w,nut (initial file at folder 0)? Best Regards |
Joachim
Actually, I think that nutLowReWallFunction is a wall function for low-Re turbulence models. If you use LaunderSharmaKE and have y+ ~ 60, you can use it for example.
Also, try using 1e-9 (or any small value) rather than 0 when imposing the BC. ![]() Good luck! |
Andre Weiner
for k:
myWall { type zeroGradient; } // or myWall { type fixedValue; value uniform 0; } Code:
myWall { type omegaWallFunction; } Code:
myWall { type fixedValue; value uniform 0; } // or myWall { type calculated; value uniform 0; // optional value entry } // what i prefer myPatch { type nutLowReWallFunction; } it sets nut to zero: Code:
tmp<scalarField> nutLowReWallFunctionFvPatchScalarField::calcNut() const { return tmp<scalarField>(new scalarField(patch().size(), 0.0)); } Code:
tmp<scalarField> nutLowReWallFunctionFvPatchScalarField::yPlus() const { .... return y*sqrt(nuw*mag(Uw.snGrad()))/nuw; } |
Epsilon boundary condition for walls in LamBremhorst LowRe model | maruthamuthu_venkatraman | OpenFOAM | 1 | April 21, 2019 06:25 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
SST model and boundary layers | Rodrigo Basniak | CFX | 7 | March 27, 2008 14:19 |
