which settings is the best for fvScheme(specially for divSchemes ) and fvSolution ? |
July 30, 2013, 03:41 |
Rep Power: 15 |
Hi All
as you know, there is many options for divSchemes, laplacianSchemes, and so on ... also there is many linear solver such as: GAMA, smoothsolver and PCG/PBiCG In OpenFoam forum there is not a good thread to explain that how we can select a good scheme and solver for different problemes please share your information about different options of fvScheme and fvSolution and compare them and explain which is the best for a specific problem Best Regards |
July 30, 2013, 06:02 |
http://www.openfoamworkshop2013.org/...rvojeJasak.tar Discretisation Best Practice for Industrial CFD with OpenFOAM might be a good read |
July 30, 2013, 08:18 |
Rep Power: 15 |
Hi Elvis
yes, it is a good document But I want to collect the suitable scheme for each different problem for example when we should use GAMG, smoothSolver or BiCG solvers ? or in divSchemes when we should use the bellow schemes for div(phi,U) ? div(phi,U) Gauss upwind; div(phi,U) Gauss limitedLinearV 1; div(phi,U) Gauss linearUpwind grad(U); and in similar way for gradSchemes and laplacianSchemes Best Regards |
Whats the procedure for choosing tolerances in fvSolution? | immortality | OpenFOAM Pre-Processing | 1 | June 15, 2013 13:55 |
how to do the fvSolution configuration - SIMPLE Foam - complex cylinder geometry | despaired student | OpenFOAM Running, Solving & CFD | 10 | July 5, 2012 04:36 |
about fvSolution settings for interPhaseChangeFoam | chueh | OpenFOAM | 4 | June 6, 2012 10:49 |
VAWT settings OF 1.5-dev | enry | OpenFOAM | 5 | July 16, 2011 00:37 |
General help for fvSchemes and fvSolution settings | harly | OpenFOAM Running, Solving & CFD | 4 | September 7, 2009 11:31 |
